First post, by bluejeans
Topbench reports a cpu of 386dx40, when speedsys guesses correctly (1/3rd of cpu speed, which is the proper moslo parameter) but then it crashes with an opcode/divide by zero error. (seems to happen with all slowdown apps) Landmark is too old to measure anything beyond a 2/386 according to someone on here. Am I going to run into problems no matter what slowdown utility I use? I don't mind speedsys crashing, since it's at least accurate, but I have to do a hard reset each time it does that.
