First post, by Guest
okay...so i got dosbox and mounted the right drive and all and it worked fine.....but when i tried to enter the folder for my game (Hellbender) it said "Unable to change to: hellbender".........why???!!!! help me please
Are you using long filenames? If so, do a dir /x and look for the 8.3 name. Avoid using long filenames for ms-dos. Naming convention for ms-dos are 8.3 (8 characters for name plus 3 characters for extension).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
i really dont know anything about dos or dosbox but i was able to get this far. the folder is just called "hellbender". thats all i know 😵
Hellbender
12345678910
10 characters
DOSBox does not support 10 character filenames or directories
Change your directory to this:
hellbend
ok thanx, got into the folder. but now i cant run the setup.exe, it says "This program requires Microsoft Windows"....i have windows!!!! 😠 help me
I don't understand why you're trying to use DOSBox to run a game that requires Windows 95: http://www.mobygames.com/game/windows/hellbender. It is not possible to do this with DOSBox.
well then how the hell do i get the damn game to work
You run the Hellbender executable in Windows? The operating system it was designed for.....
Should be Hellbndx.exe, at least that's what it is in the demo of the game that I have.
Game runs fine for me so it must be an installation problem.
If you are getting an CONFIG.NT/AUTOEXEC.NT error on trying to install the game then copy CONFIG.NT and AUTOEXEC.NT from c:\windows\repair to c:\windows\system32
now i get a box saying "This setup program is not intended to be used with your version of windows"......GODDAMNIT!!!!! someone please help me
Did you try some compatibility mode? Right-click on the main executable and choose Windows 95 or Windows 98 in the compatibility tab.
Intel i7 5960X
8 GB DDR4 (2100)
Try to enable compatability mode:
- right click on the shortcut or whatever that you're using to launch the game
- go to the compatability tab
- check the "run this program in compatability mode" box
- set the drop-down to windows 95
- hit okay
- launch the game using that shortcut (or whatever)
I also found this link that suggests the same thing: http://support.microsoft.com/newsgroups/newsR … c=en-US&m=1&p=1
Editted by eL_PuSHeR
Rewrote thread title.
Moving to Windows....
Intel i7 5960X
8 GB DDR4 (2100)
