First post, by MajorFoley
So i had an old thread back (www.vogons.org/viewtopic.php?f=33&t=367 ... 1#p321261) in the day about Alien trilogy and it's settings. I'm still messing around with it from time to time going back to a game i enjoyed back when i was a kid.
1st. I wanted to record a playthrough of Aliens trilogy, of course FRAPS can't be used as i tried it, hasnt been updated for about 4 years and can be a hog on system resources. I was wondering if any other known programs like DXtory work with Dosbox?
2nd. Dosbox games i know dont really have alot of mouse support settings, i mean for the game like alien trilogy, i can set mouse buttons keys but i can't stop movement on the Y-axis in game and change it to a look up or down motion. This would be pretty cool if i could get it working but if there is no known way i can deal with the keyboard only controls, did so in the past with DOOM and all that.
3rd. Is it worth getting a front end to use dosbox? I mean i know i have my dosbox shortcut setup for alien trilogy to use the -userconf in the command line but i dont even see a userconf for the auto command file because dosbos has some kind of bat file for opening up the config text file.
Finally during the time i play the game the old thread was about me getting to run the game smoothly which i ended up working out. The only problem i have after the fix is this kind of lurching problem. Like it seems to run smooth enough the game but sometimes it likes to lurch movements. Like for a second its going faster than it should then goes back and then it happens again maybe 5-10 seconds later. It happens alot due to movement firing etc and i was wondering how to fix it. If it's still adjusting cycles to try and fix its gonna be a long one.
Another note. I do own the original disc and i remember making an image of it, but at the time i thought it my disc may have been faulty (was so wrong about that one since the image turned out to work fine and it was my damn blu-ray player holding it back) during the time i also obtained one from the net, god knows where but the image was in a format i never really even heard of since i normally use ISO or cues. It was .MDX i think this was like an alcohol 120% format wasn't it? Anyway the file is a huge 538 MB yet when i load the image only shows as 125MB. Im assuming it's junk space for something? I'm probably gonna delete it and remake another image in a format i like that would probably also be smaller.
