AMD K6 3DMARK, aiming for stars.
Reply 60 of 601, by meljor
sdram is synchronous dram, ecc is error correction which you don't need.
I took my (delidded) k6-3+ and put it in the ga-5aa.
Max. was 5,5x110 and gave me a score of 4359 with the geforce3 ti200. As the P5a-b gave 4190 with the k6-2+ i will revisit that board to get me a final high score...it should be better with a k6-3+.
But i will get nowhere NEAR your 5k so awesome job there!
Reply 61 of 601, by meljor
Some fun on the side: put a 200mmx in the ga-5aa (same setup, gf3 ti) and and did a 3dmark2000 run.
3x66: 1259 3dmarks
2,5x110 : 1890 3dmarks
275mhz, 110fsb and 3,2v! 🤣
Reply 62 of 601, by Skalabala
meljor wrote:
Some fun on the side: put a 200mmx in the ga-5aa (same setup, gf3 ti) and and did a 3dmark2000 run. […]
3x66: 1259 3dmarks
Hahaha! Awesome stuff! I have a 233mmx that I want to try on 300mhz+-
Reply 63 of 601, by meljor
100fsb is not a problem and 110fsb also works fine but 3x100 i could not get with this one.
I stopped at 3,5v! 😎
Reply 64 of 601, by Skalabala
Nothing much to add at he moment.
The new P5AB completes post with Cache Off 120x5.5 660Mhz only 2.2V Interesting!
Going to test the new GA5AX tonight 😀 Have to update bios etc.
Reply 65 of 601, by meljor
Any good scores with the new toys?
Reply 66 of 601, by Skalabala
Not yet :p Lots of work. I need more hard drives. And my windows 98 cd that I have requires to format the hard drive in dos every time :p
Reply 67 of 601, by meljor
Download and burn the ultimate boot cd, it's awesome. For example: i also use it to simply delete, create and quick format partitions or complete harddisks. Saves a lot of time!
And ofcourse it has a lot of other useful software.
Reply 68 of 601, by Skalabala
Ok. Just did a test with the new P5A-B. 100x5.5 5500Mhz. Its faster than the other P5A-B
Very interesting. I am holding thumbs for overclock results!
Reply 69 of 601, by Skalabala
New record 😁
But however I had to push the VIO to 3.8V on this P5A-B and the other board needs 3.6V
Reply 70 of 601, by meljor
Wow! Amazing high score! Good job.
I've never even touched VIO so maybe i should have another look, also have a second p5a-b at hand 😎
How is the new k6-3+? It's really a shame that i only have one, still hoping to get another one so i can dare to take it a little bit further..
For 3dmark the k6-3+ is a fair bit faster as the k6-2+
Reply 71 of 601, by Skalabala
meljor wrote:
Wow! Amazing high score! Good job. […]
You have to make VIO more when overclocking the FSB 😀
The new K6-3+ are all stable 5X115 575Mhz
Reply 72 of 601, by meljor
Nice, but 115fsb and over 600mhz is where the gold is 🤣
I will revisit the p5a-b and play with vio to get it higher but not any time soon.
I actually got another p5a-b (my 4th!), again revision 1.04.
But I think this one will go, 3 is more than i need.
I also found another Epox board: Ep58-mvp3c-m Via mvp3 board but it is one of the first ss7 boards according to Anandtech. And It shows a little: very few voltage options and max. 100fsb so no overclock.
But still a nice board and i'm still happy i found it! It has one small defect: sdram slot1 is not working but 2 working ones are left so no problem for me.
I sold off recently the DFi baby AT mvp3 and one Aopen ax59pro (one left to keep). At this point there are still 13 ss7 boards here 😵
There must be some way to make one of them score a tiny bit higher than your score 🤣
Reply 73 of 601, by Skalabala
I must save up and come visit you! Then we build fastest socket 7 on planet! 13 motherboards I am soooo jealous!
I am going to make a wanted add for Gigabyte GA5AX with revision H chipset 😁
Reply 74 of 601, by meljor
I can not find any info about the ''H'' revision of the ALi chipset... what's the difference? All my ALi based boards have the ''E'' revision ,except for one p5a rev 1.06 that does not support the k6+ and has revision ''G''.
I have read that this ''G'' revision can cache up to 512mb but on Asus boards there is this bug so it is slow with the ''+'' cpu's. But i've never seen any info about the ''H'' revision.
Reply 75 of 601, by Skalabala
I am hoping that "H" fixed the caching problem 😀
Reply 76 of 601, by meljor
Revision ''G'' did that, but unfortunately it gave problems with the ''plus'' cpu's on Asus boards, don't know if any other manufacturer used that revision.
Hoping to find a GA5AX myself, who knows.... have been pretty lucky this year so far.
Reply 77 of 601, by Skalabala
Some candy for Super Socket 7!! Yes those are 64X128K 4ns Cache chips!!
Reply 78 of 601, by meljor
CHEATER! 🤣
Can you fix those on the board yourself?
Reply 79 of 601, by Skalabala
meljor wrote:
CHEATER! 🤣
Yes I can but my hardware is not ideal. If a pro can do it cheap then I will go that rout 😀
