First post, by Baoran
I have a Diamond Speedstar24 ISA graphics card with Tseng Labs chip that has 4 dip switches in the back. It also has 2 jumpers. One of the jumpers is labeled as IRQ2 so that is self explanatory and then there is 3 way jumper that is labeled as JP1.
Anyone has any idea what the JP1 jumper does and how to configure the 4 switches at back of the card?
If there is a manual for the card somewhere online, that would help too.
Reply 1 of 3, by CkRtech
Posted by a guy on experts-exchange from about 16 years ago -
JP1: ZERO WAIT STATE
ON (default) = ZERO WAIT STATES
OFF = No ZERO WAIT STATES
JP3: Set IRQ2 Interrupt
ON (default) = IRQ2 ENABLED
OFF = IRQ2 DISABLED
JP4: 8/16 bit BIOS ACCESS
ON (default) = 16 bit BIOS ACCESS
OFF = 8 bit BIOS ACCESS
DIP SWITCH SETTINGS:
800 x 600 Mode Setting
SW1 SW2 Monitor Retrace Timings
ON* ON* Vert. 56 Hz non-interlace, Horiz. 35.1
ON OFF Vert. 72 Hz non-interlace, Horiz. 48.1
OFF ON Vert. 60 Hz non-interlace, Horiz. 37.8
1024 x 768 Mode Setting
SW3 SW4 Monitor Retrace Timings
ON* ON* Vert. 43 Hz interlace, Horiz. 35.5
ON OFF Vert. 70 Hz non-interlace, Horiz. 56.5
OFF ON Vert. 60 Hz non-interlace, Horiz. 48.3
OFF OFF Vert. 72 Hz non-interlace, Horiz. 58.1
Switch 5 ALTERNATE TIMING SWITCH
ON* Normal Timing
OFF Alternate Timing
* - DEFAULT
Reply 2 of 3, by Baoran
That seems like a different card because my JP1 is a 3 way jumper, JP4 does not exist on my card and I also don't have 5th switch
Reply 3 of 3, by Baoran
Mine looks like the card in the pictures on this page: http://www.vgamuseum.info/index.php/component … -tseng-et4000ax
Only Differences are that the bios version number is different and ramdac chip is different. Jumpers and switches are the same. You can see the irq2 jumper in the bottom right corner and JP1 3 way jumper below the ramdac chip.
