Posted by a guy on experts-exchange from about 16 years ago -
JP1: ZERO WAIT STATE
ON (default) = ZERO WAIT STATES
OFF = No ZERO WAIT STATES
JP3: Set IRQ2 Interrupt
ON (default) = IRQ2 ENABLED
OFF = IRQ2 DISABLED
JP4: 8/16 bit BIOS ACCESS
ON (default) = 16 bit BIOS ACCESS
OFF = 8 bit BIOS ACCESS
DIP SWITCH SETTINGS:
800 x 600 Mode Setting
SW1 SW2 Monitor Retrace Timings
ON* ON* Vert. 56 Hz non-interlace, Horiz. 35.1
ON OFF Vert. 72 Hz non-interlace, Horiz. 48.1
OFF ON Vert. 60 Hz non-interlace, Horiz. 37.8
1024 x 768 Mode Setting
SW3 SW4 Monitor Retrace Timings
ON* ON* Vert. 43 Hz interlace, Horiz. 35.5
ON OFF Vert. 70 Hz non-interlace, Horiz. 56.5
OFF ON Vert. 60 Hz non-interlace, Horiz. 48.3
OFF OFF Vert. 72 Hz non-interlace, Horiz. 58.1
Switch 5 ALTERNATE TIMING SWITCH
ON* Normal Timing
OFF Alternate Timing
* - DEFAULT
