Woes with newly acquired 80286
First post, by ReCat
Hello everyone! Glad to be part of these forums.
I've recently aquired a 80286 and the first thing I did was remove the Ni-Cad CMOS battery to prevent corrosion from spreading. The motherboard fortunately has just about no corrosion from the battery.
Here is the computer in question:
Here is it's motherboard:
Here is it's drive controller:
Problem is, I can't get it to boot from the HDD or floppy drive. After configuring the FDD, it just hangs on this screen:
I've already tested two separate floppy drives which are known to be working. Not sure where to go from here. Any help would be much appreciated!
Reply 1 of 23, by kixs
Check if everything is properly connected. Floppy might as well be broken. Otherwise I see HDD isn't configured in BIOS.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 2 of 23, by ReCat
I've already quadruple-checked that and tested two other known-working floppy drives. The BIOS doesn't make any attempt to read the floppy drive apart from the initial noise when POST'ing. In that screenshot I was not attempting to boot from the HDD, and did not have the HDD connected.
Reply 3 of 23, by krivulak
Lol, the case has the front bay covers upside down 😁
Also, the CPU is 12 MHz by the way, not 16 MHz, but you sure know that.
Anyway, I would use another controller if you have any on hand.
If that doesn't work, then I would try BIOS flash, but finding anything suitable today is impossible.
Reply 4 of 23, by ReCat
Bay covers up are side down? Huh, how can you tell? :p
I actually didn't know the frequency of the CPU, I only got this PC 2 days ago. Good to know though.
I don't have any other controller at hand, but If you think that could be a possible cause I may be able to borrow one from a mate.
I'm going to try powering the empty CMOS battery socket to see if that makes any difference...
Reply 5 of 23, by krivulak
If you look at old XT drives like Seagate ST-225, you can see that the perforated part is meant to be on bottom to match the harddrive. Like on this photo: 23.jpg
Anyway, missing CMOS battery shouldn't be a problem, but you can try it if you want. Also try cleaning contacts on the controller card with some alcohol, it could help. And try to re-seat every socketed chip, there might be a little bit of oxidation that prevents good contact.
Also, now I noticed that the tantalum cap on the left bottom between the Goldstars chip seems damaged, maybe little cracked. It might be a problem.
Reply 6 of 23, by ReCat
Interesting! I'll try those suggestions. And yes, that tantalum does seem to have some kind of cosmetic mark on the outside, but it's not cracked. I've taken it out and measured it on my ESR meter, and it seems to be within tolerance.
Reply 7 of 23, by Stiletto
Moderator here, edited the original post's imgur embeds due to the extremely large photos expanding beyond the post's borders. We're a retro forum, some of us have very tiny screens. I typically browse in 1366x768 😉
In the future, check out Stiletto's guide for using imgur with VOGONS. Welcome, by the way 😀
do the Fandango!" - Queen
Stiletto
Reply 9 of 23, by kanecvr
some boards refuse to boot when the BIOS battery is missing.
Reply 10 of 23, by ReCat
Alright, Thanks, I thought the forums were going to auto-scale the images like some other forums I attended, but then figured it's alright.
clueless1 wrote:
Cables plugged upside down?
I've checked! FDD drives also constantly have their lights on when it's upside down..
OK, Now I'm definitely going to try replacing the battery somehow and see what it does, Thanks
Reply 11 of 23, by jesolo
ReCat, welcome to Vogons.
Where are you based?
My father's 386 PC had exactly the same case.
You might also want to open your PSU and have a look at the capacitors on there.
I also recently acquired a 286 and after also having problems with my hard drive booting up I realised that the PSU was the culprit.
Reply 12 of 23, by ReCat
jesolo wrote:
ReCat, welcome to Vogons. Where are you based? […]
europe, i've bought this PC at a car boot sale recently for €5 so it could be imported for all I know since i haven't read the HDD yet
and good idea, I will check the voltages on the power rails too, thanks
Reply 13 of 23, by Jo22
What happens if no floppy controller is present ?
Does the mainboard complain then ?
Reply 14 of 23, by cj_reha
That's a pretty cool 286 motherboard, it even has places for SIPP memory to be used.
Man, you guys find cool stuff at car boot sales 🤣
Anyways, my experience is that a floppy disk may be picky from which drives it's read on. I have one that refuses to read on a good drive in one machine, and reads fine in another.
Reply 15 of 23, by ReCat
I'll try that and report back
The problem is it made no attempt to read it either, it's just completely silent. It did however make a noise when first initializing the drive, which sounds normal.
Reply 16 of 23, by ReCat
Alright, If I boot up the mobo without a floppy controller or with the floppy drive disconnected from the controller I get this same error:
i've also cleaned the contacts of the controller card, as well as checking the voltages of the PSU, and both seem to be within 2% of their target voltages when booting up.
I've also soldered on a CR2032 battery holder and battery onto the mobo, providing 3V which is within the charge range of the original Ni-Cad 3.6V, it seems to have made no difference although the CMOS successfully retains it's settings and time now.
Pretty bummed out. I'm going to try to see if I can test the HDD and the drive controller in my P1 machine next.
Reply 17 of 23, by Baoran
I have had problems booting with goldstar card as well which I talked about in this thread Re: Problem with my ISA I/O card
Not sure if our problems are related.
Reply 18 of 23, by ReCat
Interesting. For me the only noise and LED light my floppy drive makes is when POST'ing. Nothing when it is supposed to start reading the disk.
Reply 19 of 23, by Jo22
ReCat wrote:
Alright, If I boot up the mobo without a floppy controller or with the floppy drive disconnected from the controller I get this same error:[..]
Hmm. Ok, seems the board is behaving normal so far. If you can, try another floppy cable. A modern, non-twisted type (for a single drive) for example.
