First post, by ReCat
Hello everyone! Glad to be part of these forums.
I've recently aquired a 80286 and the first thing I did was remove the Ni-Cad CMOS battery to prevent corrosion from spreading. The motherboard fortunately has just about no corrosion from the battery.
Here is the computer in question:
Here is it's motherboard:
Here is it's drive controller:
Problem is, I can't get it to boot from the HDD or floppy drive. After configuring the FDD, it just hangs on this screen:
I've already tested two separate floppy drives which are known to be working. Not sure where to go from here. Any help would be much appreciated!
