First post, by keropi
Hiya!
I have a couple 16mhz 286 motherboards with the Headland HT12/A chipset and I was wondering if there is a UMB driver for it.
I have tried "The Last Byte Manager" that provides up to 64kb of UMBs for the HT12 chipset but all it does is hard-lock both machines... 😢
Perhaps there is a HT12 chipset without the /A and that's why it doesn't work 😕
The HT12MM.SYS EMS driver does work and provides EMS RAM but no UMBs. Is it even possible?
Here are some photos from the chipset, BIOS screen and TLB manager:
and here is the MEM output with HT12MM.SYS loaded to provide EMS:
Any ideas/tips?
TIA for any help/info! 😊
Reply 1 of 20, by dieymir
Try disabling memory relocaton in BIOS setup. As last resort you can have UMBs using the generic EMS 4.0 support of TLBMM, QRAM or Invisible RAM. I have used all of them successfully with my 286 mainboard and a SUNTAC Chipset.
Reply 2 of 20, by jesolo
I have a 386SX PC with a Headland HT18 chipset, but have not been able to locate any EMS driver for it.
In the BIOS, there is an option to allocate some memory as EMS, so I'm assuming there must be a driver for it as well.
Reply 3 of 20, by Jo22
Wait, there's an EMS driver ? I'm also having a Headland-based machine! Where can I find it ?
Reply 4 of 20, by keropi
I am attaching the HT12MM.SYS driver , it's the hardware EMS driver for the HT12 chipset, don't know if it will work with others
supposedly there is also a "ht12-umb.lzh" but noone seems to be able to locate it...
http://www.vcfed.org/forum/showthread.php?275 … and-EMS-drivers
    ht12.zip
    10.83 KiB
    224 downloads
    HEADLAND HT12 EMS Memory Manager
Reply 5 of 20, by Jo22
Thank you very much! ^^
Reply 6 of 20, by keropi
The solution was here all along 🤣 according to this post:
With The Last Byte Memory Manager 2.11 version works the umb (i can get 62kb umb), only you should delete the frame=d000 options at the config.sys lastbyte.sys command line. The olny problem is the program is sharware (wait 30sec, works only 30days), and you couldn't use ems/umb at the same time (because the ems page frame uses as umb).
So I downloaded the older v2.11 version of TLB and it actually works! Apparently the latest v2.52 broke something - at least on the chipset program.
DOS 6.22 cannot recognize the UMBs that TLB creates, programs do load fine though in that region but you have to use TLB's HIGHTSR loader, LH does not work:
So unless that special HT12 UMB driver is found TLB is the only way that works and creates UMBs, at least on my systems.
Thanks everyone for their help!
edit:
turns out that the problematic part is the CHIPSET.EXE detection program that TLB v2.52 comes with... the driver is loading fine:
this is the config.sys command for the HT12 chipset: DEVICE=C:\TLBMM\LASTBYTE.SYS Physical=HT12,NOEMS,OVERRIDE
doing a full install of TLB v2.52 with "INSTALL HT12" (so that chipset.exe that is problematic does not run) takes care of the UMB integration in DOS, MEM reports UMBs and LH works.
Reply 8 of 20, by keropi
HT12 has hardware EMS support, you set the size in BIOS and then use the driver I attached in a previous post.
EMS though won't give you UMBs, that's a different story and you need The Last Byte for that.
Reply 10 of 20, by keropi
no idea what's the deal then... see my BIOS screen in the first post - both HT12 boards I own are the same
Reply 14 of 20, by keropi
well is seems EMS function is disabled for some reason... no idea if there is a chance to work with any trick
Reply 15 of 20, by derSammler
dr.zeissler wrote:
Interesting, my TowerAT also had a HT Chipset, but no EMS was possible.
The Tower AT does not have a HT12 chipset. It's using the GC102, but EMS is only supported with the GC103.
Reply 18 of 20, by keropi
FreddyV wrote on 2023-01-06, 16:07:
@keropi
I know it is an old post but where I can get all these memory management tools ?
what tools are you referring to?
Reply 19 of 20, by FreddyV
keropi wrote on 2023-01-06, 16:17:
@keropi
The Memory management / diagnostic tools, like Manifest
