First post, by Tetris Ling
I'm trying to get Sierra's old NASCAR Racing 2 to run on Windows XP.
The problem is a crash that dumps the following text to the screen:
Running from C: drive
UniVBE driver not present
543488 Conventional 15367492 Normal 15367492 All 15367492 Largest
pmTable available at 000c5aeb (383 bytes)
Triple Buffering
Card has 134152192 bytes on it...
linear selector = 0000
base address = 983183bc
DOS/4GW Professional error (2001): exception 0Dh (general protection fault) at 3
BF:02AF4974
TSF32: prev_tsf32 80C4
SS 3C7 DS 3C7 ES 3C7 FS 0 GS 17F
EAX 983183BC EBX 50000 ECX 50000 EDX 0
ESI 983B83BC EDI 2C583A0 EBP 2C5839C ESP 2BF51D4
CS:IP 3BF:02AF4974 ID 0D COD 0 FLG 213206
CS= 3BF, USE32, page granular, limit 7FFEFFFF, base 0, acc C7FB
SS= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
DS= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
ES= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
FS= 0, USE16, byte granular, limit 0, base 0, acc 0
GS= 17F, USE16, byte granular, limit FFFF, base DC90, acc F3
CR0: unavailable
Crash address (unrelocated) = 1:00094974
I get this error message whether or not I run it with VDMSound.
(Incidentaly, the configuration program runs just fine).
Any help would be fabulous.
-Tetris Ling
Reply 1 of 5, by HunterZ
You might try NOLFB (search the forum). Just a shot in the dark.
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
Or try replacing that DOS/4GW module with DOS32A (search the forum or the Wiki for instructions on how to do that).
Edit: I'm feeling genours today:
[ANN]: DOS/32A v9.1.2 has been released
_________________
Reply 3 of 5, by VirtuaIceMan
It'll work in DOSBox but way too slow. If you get anywhere keep us posted!
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 4 of 5, by DosFreak
The 4GW extender probably isn't compatible with the XP stub. I've seen this before. Don't have the game but you should try the above suggestions...especially the DOS32A one.
You could also try MS VPC or DosBox.
Make your games work offline
Reply 5 of 5, by Tetris Ling
An update:
With an arcane combination of NOLFB, DOS32A, and VDMSound, I have gotten the game to tell me I don't have enough conventional memory to play.
I have to assume this is good news; usually it quits long before it even bothers to check my memory.
[sigh] Buckets of RAM, and my life is still controlled by 640K of dumb conventional memory...
Update: A little more tinkering with my VDMS settings (increasing the amount of Expanded Memory available), and now it works perfectly, at full speed and everything. Neat.
