First post, by Tetris Ling
I'm trying to get Sierra's old NASCAR Racing 2 to run on Windows XP.
The problem is a crash that dumps the following text to the screen:
Running from C: drive
UniVBE driver not present
543488 Conventional 15367492 Normal 15367492 All 15367492 Largest
pmTable available at 000c5aeb (383 bytes)
Triple Buffering
Card has 134152192 bytes on it...
linear selector = 0000
base address = 983183bc
DOS/4GW Professional error (2001): exception 0Dh (general protection fault) at 3
BF:02AF4974
TSF32: prev_tsf32 80C4
SS 3C7 DS 3C7 ES 3C7 FS 0 GS 17F
EAX 983183BC EBX 50000 ECX 50000 EDX 0
ESI 983B83BC EDI 2C583A0 EBP 2C5839C ESP 2BF51D4
CS:IP 3BF:02AF4974 ID 0D COD 0 FLG 213206
CS= 3BF, USE32, page granular, limit 7FFEFFFF, base 0, acc C7FB
SS= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
DS= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
ES= 3C7, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
FS= 0, USE16, byte granular, limit 0, base 0, acc 0
GS= 17F, USE16, byte granular, limit FFFF, base DC90, acc F3
CR0: unavailable
Crash address (unrelocated) = 1:00094974
I get this error message whether or not I run it with VDMSound.
(Incidentaly, the configuration program runs just fine).
Any help would be fabulous.
-Tetris Ling
