First post, by jheronimus
- Oldbie
Hi, all
I have a desktop AT case that I got maybe a couple of months ago. Probably from 386 era. In Russian these cases got a nickname "crocodile" due to the fact you can just open the "hood" without removing any screws. It's similar to this one:
I tend to use this case for a lot of new builds, because it's really convenient. However, it suffers from a problem where sometimes turning the PC on results in white screen, all the LED indicators on the keyboard staying lit, and the PC not responding to any input. I've been mostly using this system to test 5x86/VLB configurations which tend to be tricky.
However, with my latest board (QDI V4P895GRN/SMT v1.0 (S1.1)) I knew for a fact that it's set up correctly — the seller tested it with the exact same CPU, and I've used RAM and VLB videocard from my previous builds. The symptoms are the same, however: when I turn the power on, the screen gradually turns white (no output from the system whatsoever), doesn't POST and doesn't react to keyboard input. The keyboard LED indicators (Caps Lock, Num Lock, Scroll Lock) stay lit the whole time.
Here's what I've tried:
1) different RAM sticks/different RAM configuration;
2) reseated the VLB card
3) tried another AMD 5x86 (the very same model, though)
4) finally, I realised that it's probably not about the mobo. I removed it from the case and plugged the PSU into a different board (Intel's Batman Revenge, if that matters). I've placed the mobo on a wooden board outside of the case (the PSU is still in the case), installed a PCI video card — and it worked just fine.
5) I then connected the QDI board back — same configuration, but placed outside of the case. After a couple of attempts it also worked.
So at this point I'm fairly convinced, that the issue is with the case/PSU. Any ideas what could it be? Thanks in advance!
