First post, by vglover2005
Tomb Raider w/gold runs fine untill the intro where it loads the FMV (Full Motion Video) files. It cuts short and then it loops the sound back a sequence untill you press ESC. I tried ESCAPEplayer and basicly the same thing happened without those 640X480 lines.
I think it has something to do with VESA not keeping up with the stream data because it does play, for a second, but the point is, it's reading the file correctly... Well Sort of.
Thanks for any suggestions
