First post, by okenido
Hello
I have a lil problem, no drivers seems to work for my HD4650 on XP SP3 32bits. I tried the official catalyst from amd website ( http://support.amd.com/en-us/download/desktop … erOnServer=true ), the install seemed to work but the driver wasn't installed. There is an html report generated and it claims the driver can't be installed since it's not digitally signed.
Then i tried the catalyst hotfix for agp cards (http://support.amd.com/de-de/kb-articles/Page … tAGPHotfix.aspx), it correctly showed the Windows driver install popup, copied all the files but then black screen with a blinking cursor (like DOS) when the program installs 'ATIODE.EXE' at the end of the progress bar. I'm forced to press the power button since at this point nothing responds. Next boot is like no driver was installed, still the microsoft default VGA adapter.
I already tried several things like resetting my overclocking, disable AGP fast writes, set AGP in 2x mode, didn't changed anything. Motherboard is an Asus P3V4X, Via Apollo Pro 133A chipset. CPU is a PIII coppermine 933, 512mb ram
I don't know what to do now. I saw several guys on youtube with hd4650 and Pentium 3, so I guess it's not a problem with the lack of SSE2 for the drivers. Do you have any ideas ?
