First post, by okenido
Hello
I have a lil problem, no drivers seems to work for my HD4650 on XP SP3 32bits. I tried the official catalyst from amd website ( http://support.amd.com/en-us/download/desktop … erOnServer=true ), the install seemed to work but the driver wasn't installed. There is an html report generated and it claims the driver can't be installed since it's not digitally signed.
Then i tried the catalyst hotfix for agp cards (http://support.amd.com/de-de/kb-articles/Page … tAGPHotfix.aspx), it correctly showed the Windows driver install popup, copied all the files but then black screen with a blinking cursor (like DOS) when the program installs 'ATIODE.EXE' at the end of the progress bar. I'm forced to press the power button since at this point nothing responds. Next boot is like no driver was installed, still the microsoft default VGA adapter.
I already tried several things like resetting my overclocking, disable AGP fast writes, set AGP in 2x mode, didn't changed anything. Motherboard is an Asus P3V4X, Via Apollo Pro 133A chipset. CPU is a PIII coppermine 933, 512mb ram
I don't know what to do now. I saw several guys on youtube with hd4650 and Pentium 3, so I guess it's not a problem with the lack of SSE2 for the drivers. Do you have any ideas ?
Reply 1 of 8, by sprcorreia
Try do download directly from the manufacturer.
Reply 2 of 8, by agent_x007
Don't worry about it.
Download driver, and let it unpack to ATI(AMD)\Support\"whateverversionyouuse" folder.
Then, exit installer and go to Device Manager.
Pick your "VGA Compatible" device (that should be your GPU), and from it's propietes pick Update Driver.
When ask for Autoinstall/Manual - pick Manual
When ask about driver folder, pick "I will pick driver to install" option.
Then you click on "Have a disk" and you browse to folder where installer unpacked itself.
Deault is : "OS drive":\ATI\Support\"whateverversionyoupicked"\Packages\Drivers\Display\
"whateverOSyouareusing"\xxxxx.inf
After you pick that file, in next window you should get list of compatible devices.
If setup didn't find your gpu, you have to pick it yourself from list (it's either listed as "4650" or "4600 series").
Confirm you want to install that driver and let setup do it's thing.
After it's done, restart your PC, and you should be good to go.
ALWAYS let the unsigned driver install.
If that doesn't help, it may be a dead GPU, OR (more likely) MB isn't compatible eith that card.
Remember that DX10 series cards all have PCI-e to AGP bridge chip on PCB.
If your MBs BIOS doesn't like it - GPU will not work correctly regardless of what you do.
PS. HD 4650 driver is too CPU heavy to use that GPU efficiently.
You would be better off with X1950 Pro in that PIII setup.
Reply 3 of 8, by okenido
Thank you for your answers,
At first it seemed better with the manufacturer driver since it completed the installation. It's this one : https://www.asus.com/Graphics-Cards/AH4650DI1GD2/
But I got a black screen at the next boot. Same black screen as with the previous driver but during boot. I can still boot in fail-safe mode. Uninstalled it and tried again, this time with .NET framework installed since I had a message telling me the catalyst drivers need them, but same result, either black screen or windows discards the driver and fallbacks to its default vga driver.
I feel a bit unlucky. I'll try with another motherboard, i have an oem 'Gateway' one which is based on 440BX, but i doubt it will work, it's older than the via 133A chipset
Reply 4 of 8, by agent_x007
I'm pretty sure you can't use HD 4650 on 440BX because that chipset doesn't support 1,5V AGP (it's 3,3V only), and your card requires AGP 1,5V or lower to work (check notches on AGP port and AGP slot before installing).
However I can be wrong...
Reply 5 of 8, by Xeen
Does the trick work for 4670 Agp cards in Win98?
Which catalyst driver version should I download?
Reply 6 of 8, by Strahssis
okenido wrote:
Thank you for your answers, […]
Is the screen black entirely or is it just extremely dark in such a way that it is unusable? I once had an issue with an extremely dark screen with my ATI Radeon 6370M and the Catalyst drivers, so I went into Safe Mode and I changed the brightness settings in the registry, which fixed the problem for me. At first I thought as well that the screen was black, but when I looked better, I noticed that the screen was extremely dark instead of black. 😜
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 7 of 8, by PentAmd
Old thread, but I have the same problem.
I have WinXP SP2 (!) so I am not able to install calatalist, because some programs are missing.
But I wanted to install the display driver. I downloaded the latest xp driver from the AMD website. Version Nr. is Catalist Legacy Beta 13.4
I extracted the EXE file, and installed the driver via Device Manager from C\ATI\...
After the files were copied, I saw a black screen with blinking cursor on the top left corner. The first time I reboted with reset button, but the second time I done some internet surfing on my other computer, so I left that black screen state. After a long-long time (ca. 5 minutes) the sceen came back to windows, and says the driver ready installed.
I said ok, now a reboot needed. During the boot where the WinXP logo and the moving blue dots are shown, the movement of the dots were stopped. I thought something freezed again, but I waited. After a long time, I saw the desktop.
I checked the device manager, everything was fine. 3Dmark01 (for DirectX 8 ) produced 12724 Points. There was a point in the high-quality car chase scene, where the truck is hit by the big drone and the other car fires a missle, there the FPS gone to almost 1 and was choppy. In the high wuality "matrix" scene there was also a point, where FPS gone down. In the "Nature" scene at the lake shore lot of leaves were missing.
System is dual Athlon MP 2800+ (266FSB), with universal (4x) AGP slot.
After a reboot, I had the same problem, that I had to wait. Now I measured it, that was 2,5 minutes.
I disabled the 2nd processor, to see what difference does it make. During bootup I had to wait again the 2&half minutes. I started the 3Dmark again, and everything above mentioned was the same, the score was 11697.
This card is not good for older DirectX like 8. I just wanted to try out. I think with 3850 I would have the same disappoitment.
Reply 8 of 8, by agent_x007
Try to use older Catalyst, 9.1 or 10.2 (DDU is your friend to get old driver erased, it just needs old version to work).
Also, device menager driver installation is sometimes required.
As for missing files, that's because some installers were renamed at one point.
It's best to go with files size vs. slimmer version, instead of pure naming (driver with catalyst control, should have "CCC" in it's name).
