First post, by sf78
Any info on these? The first two particulary.
About the third one: Control Systems Artist 1 was an MDA clone; Control Systems Artist 12 had two (or more) outputs. But I can't find anything about the Control Systems Artist 8, which is what the label seems to say.
wrote:But I can't find anything about the Control Systems Artist 8, which is what the label seems to say.
Always try google books, sadly full page is not available - Computers in Mechanical Engineering from 1988...
Control Systems Corp. has begun shipping its newly introduced Artist 8, a graphics controller board for the IBM PC, XT, AT and compatibles. The unit includes the vendor's Artist GT software, an AutoCAD-enhancement interface that works with add-on EMS memory and display-list-processing techniques to add faster redraws, zoom, and transparent, concurrent pans to normal AutoCAD performance. The board uses Hitachi's ACRTC ...
There is also small mention at Design News 1989...
Resolutions range from the ARTIST 8 at 800 x 600 to the pixel-packed ARTIST XJ12 with a 1280 x 1024 resolution. One of the features of MicroStation is its ability to utilize two high-resolution screens.
Not only mine graphics cards collection at http://www.vgamuseum.info
I found an article that is related to the board in the first picture.
It is related to moniterm viking I and under the picture it says that the board is powered by the monitor and not the pc.
The hitachi controller in your picture is also mentioned in the article.
https://books.google.fi/books?id=KU7dCBpP7fsC … roducts&f=false
The HD63484 appearing on the first two cards is an "Advanced CRT Controller." The datasheet says it has drawing functions (ie. hardware acceleration). The first card looks like it has 256KB of 32-bit bus DRAM and two monitor ports (is it a 9-pin and 15-pin?) so my guess is a hyped-up EGA clone. Could be VGA.
The bottom card has an MC6845 and eight 64kx1 150ns DRAMs. Too slow to be EGA but more RAM than standard CGA. Maybe it has extra screen modes like a Plantronics or something.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
wrote:The HD63484 appearing on the first two cards is an "Advanced CRT Controller." The datasheet says it has drawing functions (ie. hardware acceleration). The first card looks like it has 256KB of 32-bit bus DRAM and two monitor ports (is it a 9-pin and 15-pin?) so my guess is a hyped-up EGA clone. Could be VGA.
Thanks everyone! All the cards have 9-pin output, except the Moniterm card (1st pic) which also has (I presume) a 9-pin input/pass-through connector.
