First post, by muon
Hi!. I have a Chicony mainboard. The battery is in the end of life: it works properly, because it still keeps the CMOS RAM information, but it is dropping the acid:
Suggestions ?? Recommendations ??
I was thinking of removing it - cutting with the scissors the splice points. is it right? - and replacing it with another one. I don't know if this kind of battery is available now. The model can be seen in this other picture:
Or would you put something else ?? The motherboard without battery would work ? (if I know, when it goes out CMOS RAM "forget" the values , but does it work properly?)
Thanks in advanced
Reply 1 of 4, by Anonymous Coward
Looks like it's not leaking yet, it's just rusty. You should remove it ASAP.
J10 should be an external battery header, and you can still buy the lithium battery packs (or make your own).
You can use something like a pair of nail cuticle clippers to remove the barrel battery.
Reply 2 of 4, by jesolo
Second Anonymous Coward's recommendation.
Here's a reference guide: http://pc-restorer.com/replacing-cmos-batteries-in-old-pcs/
Easiest method is to remove the barrel battery and replace it with a battery pack by connecting it to the external battery header. The external battery header is normally non-chargeable.
If you do wish to use the existing connectors, and you use non-chargeable batteries, be sure to place a diode in between.
Reply 4 of 4, by gdjacobs
I solder leads onto the battery contact points and use 3.6V NiCd battery packs from cordless phones. I always tape or tuck the battery into a position so it won't drain onto anything sensitive in case of a leak.
NiMH should work fine as well if NiCd is unavailable due to environmental regulations.
