First post, by muon
Hi!. I have a Chicony mainboard. The battery is in the end of life: it works properly, because it still keeps the CMOS RAM information, but it is dropping the acid:
Suggestions ?? Recommendations ??
I was thinking of removing it - cutting with the scissors the splice points. is it right? - and replacing it with another one. I don't know if this kind of battery is available now. The model can be seen in this other picture:
Or would you put something else ?? The motherboard without battery would work ? (if I know, when it goes out CMOS RAM "forget" the values , but does it work properly?)
Thanks in advanced
