First post, by ahtoh
I was thinking about taking an image copy of the HDD because I believe the PC is in its original condition and I would like to save it just in case.
Reply 1 of 12, by .legaCy
If it don't have any propietary shenanigans it should work.
Reply 2 of 12, by Gahhhrrrlic
Your modern board needs an IDE controller obviously but as long as the HDD shows up in the BIOS and has an older file system than what your new computer is running I don't see why it wouldn't read. Just have an antivirus running in case of surprises and you should have no trouble talking to it.
https://hubpages.com/technology/How-to-Maximi … -Retro-Computer
Reply 3 of 12, by Jo22
Back in time, I used a bootable disk of Acronis True Image (v7 ?) to create disk images of IDE drives..
Reply 5 of 12, by cricket
If you find a "modern PC" that has IDE, sure why not?
Reply 6 of 12, by ahtoh
Yeah by "modern" pc I meant Pentium-4 😀
Figured out my Acronis true image 2018 USB boot stick does not work on this machine. simply freezes on boot worked on many other newer machines.
what a shame.
Can anyone suggest a bootable CD/USB tool that can take an image of the HDD and put it on an USB stick?
Reply 7 of 12, by Qjimbo
ahtoh wrote:
Yeah by "modern" pc I meant Pentium-4 :) Figured out my Acronis true image 2018 USB boot stick does not work on this machine. si […]
what a shame.
Clonezilla is bootable and should be able to do it I think.
Follow me on twitter
Reply 8 of 12, by ahtoh
Acronis booted while I was posting the previous message 🤣.
It was just slow I guess
Reply 9 of 12, by PCBONEZ
Or...
https://kb.acronis.com/content/2711
Reply 10 of 12, by leileilol
I wouldn't use Acronis (proprietary .tib files = ick). I think I used something off the Ultimate Boot CD to image my old IDE drives (40-400mbish) without booting an OS in 2008 but forgot which one it was that dumped to an .img file.
Reply 11 of 12, by PCBONEZ
My point wasn't to convert it to SATA but that older versions of Acronis are compatible with IDE to make the image.
Acronis wouldn't be my choice either but the OP appears to be familiar with it.
Reply 12 of 12, by ahtoh
I remember I had issues restoring a backup to a slightly smaller drive using clonezilla. So this program is a no-go for me.
Acronis seem to work just fine.
