First post, by jamiguel77
how modify or create an autoexec.bat or a config.sys ??
i use windowsxp..
thanks
Reply 1 of 8, by eL_PuSHeR
Hello. Welcome to the forums!
There are no CONFIG.SYS nor AUTOEXEC.BAT under Windows XP.
There were plain text files for the ms-dos era. Why do you want to modify them?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by jamiguel77
because:
i use 1 pc with win98 OS, have a dos app and i can display 1 report... i try install same DOS app ina windowsxp and not worked (i modified config.nt files=80 buffers=80 fcbs=34,4) any advice why not worked?
i try modify the compatibility and not worked...
try with dosBox and not worked....
thanks
Reply 3 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I wonder when people learn to post properly. Well, at least posting the name of the program could be usefull. Most of people around here are not psychics...
Mirek
Reply 4 of 8, by jamiguel77
mirekluza sorry for my bad english, sorrrryyyy
Reply 5 of 8, by mirekluza
DOSBox Moderator
I have nothing against your English, I just want you to post the name of the DOS game/application you are trying to run...
Mirek
Reply 6 of 8, by eL_PuSHeR
What is the name of the program that is giving you problems?
If it's a clipper program you may also need to set a variable called:
SET CLIPPER=F80
For 80 files. Keep posting. If this is the case, using VDMSound worked for me (oddly enough).
*** Moving to DOS section, by the way ***
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 8, by jamiguel77
i need setting/configure:
is a Dos app ( Cobol )
thanks
Reply 8 of 8, by eL_PuSHeR
Use VDMSound. Edit the advanced settings tab and specify those values there. With luck, it should work.
Intel i7 5960X
8 GB DDR4 (2100)
