First post, by appiah4
- l33t++
SB AWE32 CT3980W with Dreamblaster S2 installed. Whenever I try to set and test General MIDI in Sam & Max Talkie CD edition's setmuse program, the computer hard locks. I've tried it at 133MHz and 100MHz, and I've tried it with SoftMPU and without Soft MPU. I've even tried AWE32's MT-32 emulation and the Roland option and it's the same behaviour. Is there a workaround? Everything works fine in DOTT Talkie CD.
