First post, by appiah4
SB AWE32 CT3980W with Dreamblaster S2 installed. Whenever I try to set and test General MIDI in Sam & Max Talkie CD edition's setmuse program, the computer hard locks. I've tried it at 133MHz and 100MHz, and I've tried it with SoftMPU and without Soft MPU. I've even tried AWE32's MT-32 emulation and the Roland option and it's the same behaviour. Is there a workaround? Everything works fine in DOTT Talkie CD.
Reply 1 of 5, by Jo22
Depending on the version of the game, try updating DOS4GW or replace it with DOS32A.
Maybe that helps, but I'm not sure. Also, there was an update for Sanm&Max once.
It fixed the save state feature. Maybe it contains other bug fixes, too. Not sure, though.
Anyway, good luck! 😀
Reply 2 of 5, by DataPro
Hello,
I've got the same problem.
Config : Pentium 166 Mhz, 112Mo RAM, AWE64 + Roland MT32 + Roland SC88
Day of the tentacle, Indy & Fate of Atlantis or Sam&Max Floppy version run fine with soundblaster + General Midi.
My game is patched with this one : https://www.patches-scrolls.de/patch/3562/7/49775/download
The game only works when music is set on adlib or OPL4
HP Vectra 562 P166Mhz/256Ko L2 cache - 112Mo RAM - 2x4Go SSD - Matrox Mystique 2Mo - SB AWE64 ISA (PnP) + Roland MT-32 + Roland M-GS64 -5 USB 2.0 ports - multicard reader
