TKay wrote:Compact flash is also being phased out, SD cards are far from ideal. Is this the end of the road for the old IDE interface? x)
There's also a Compast Flash successor, called CFast. It's based on SATA, but might be backwardscompatible to IDE/ATA similar to SATA HDDs.
Even if it won't, there will be adaptors for sure. See http://www.microsatacables.com/ide-44-pin-to- … de44p-cfast-hsg
IDE/ATA is quite simple to implement. All we really need for DOS is WD1003 or ATA0 register set comaptibility, anyway.
These things could be implemented with the help of microcontrollers or FPGAs, for example. Don't worry.
Quite more complex things had been build already.
I'm just thinking of old mainframes that got their huge tape storage system emulated on an old WinXP laptop. 😉
