First post, by ultra_code
- Oldbie
Hello VOGONS members!
I recently got my hands on a Creative AWE64 Gold, and while cleaning it (it was absolutely disgusting), I noticed some slight corrosion on the gold-plated audio ports. Since it wouldn't come off with 91% isopropyl alcohol (at least in any reasonable amount), and CLR is out of the question, does anyone have any recommendations on cleaning solutions that can safely remove this slight corrosion off the ports? Also, if I decided to leave the corrosion on the ports, would it significantly affect the outputted sound's quality in any meaningful way?
Sorry that it is kind of hard to see.
