First post, by CarlHopkinsUK
If you can live with a glossy screen, you can always remove the antiglare film completely.
Basically you remove the panel from the monitor, loosen the glue by means of paper towels you keep moist (but not drippingly wet, you don't water inside the panel) for a day or so, and then carefully peel the film away.
Found a video of the removal process; https://www.youtube.com/watch?v=I5UQFlJCmrs
