First post, by Pronto
Here's the deal. I'm looking at DOSBox to run a DOS based car tuning software that uses the parallel port to hookup to the ECM. Would DOSBox allow the software to run and see the info from the parallel port? The software is known not to run on XP. Thanks.
Reply 2 of 4, by Guest
Are there any emulators out there that will see the parallel port?
Reply 3 of 4, by Guest
I'm sick of seeing people asking for paralell port support in DOSBox,too. I think the only solution to this problem is to just add it. At least it should shut them up. Besides, how hard can it be to implement for an experienced programmer?
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
The question is not how hard it is. It's more like do harekiet and I want it in DOSBox.
You can guess the answer.
Water flows down the stream
