Does DOSBox see parallel ports?
First post, by Pronto
Here's the deal. I'm looking at DOSBox to run a DOS based car tuning software that uses the parallel port to hookup to the ECM. Would DOSBox allow the software to run and see the info from the parallel port? The software is known not to run on XP. Thanks.
