My 3DMark01 Mega Thread
Reply 680 of 864, by SPBHM
it's annoying to see the variation with driver version, with my stock FX 5900XT on a P4 with the 845PE it get around 12.5k with the latest driver, 13.8 with 93. something and 14.8k with 53.03...
(all on XP SP3 and with the default driver quality settings).
oh well, GMA 950 is not so bad on 3dmark 2001!
The attachment 3dm01gma950v.JPG is no longer available
Reply 681 of 864, by Shagittarius
Just got my new CPU, haven't done any overclocking to it yet, or gotten my XMP 4133Mhz Ram setup yet:
The attachment 9900krtx2080ti.jpg is no longer available
The attachment 3dmark2001se.jpg is no longer available
Reply 682 of 864, by The Sandman
Here are my Scores:
Config: Abit KT7A @ 150-MHz FSB/RAM, CL2 everything on Turbo, Athlon XP-M @ 1800-MHz, 1,28VCore, GeForce 4 Ti 4200 (Albatron, simple layout) AGP x8 @ default (GPU 250-MHz/ MEM 513-MHz) and of course 43.45 Drivers.
Intellisample @ HQ
Intellisample @ HP
without changing any setting my score miraculously raised to this 😳
After the strange Rise Of The G-Raider I can proudly submit this Score (overclocked GPU)
11089 Points are imho pretty good. Windows 98 at it's best
Reply 683 of 864, by Errius
As it is a benchmark and is meant to test your system performance, there are no strict minimum requirements. However, our offici […]
As it is a benchmark and is meant to test your system performance, there are no strict minimum requirements. However, our official minimum requirements are 128 MB of RAM, a 500 MHz Intel-compatible processor and a modern 3D accelerator with 32MB of video memory.
The 128MB of memory is an absolute requirement, but you may be able to run it with a slower CPU and an 8 or 16 MB graphics card. Beware - it is definitely not meant for low-end systems.
The benchmark is meant for the games of the future and will require high-end hardware. A new Pentium III, Pentium 4, Celeron (SSE), Athlon or Duron system is recommended, as is a Hardware T&L compatible 32MB 3D accelerator. A fully DX8 compatible card wouldn’t hurt either, although unfortunately, there aren’t that many out there.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 684 of 864, by noshutdown
the slowest cpus that can run 3dmark01 are idt winchip and cyrix 6x86.
slowest video cards that can finish 3 tests at lowest resolution(640*480*16bit) are sis6326 and s3trio3d.
slowest video card that can finish 3 tests at default resolution(1024*768*32bit) is matrox g200-16mb.
slowest video card that can run all 4 tests is r9200se.
also, i think running on 64mb machine is possible, especially with a tidied up win98.
Reply 685 of 864, by Errius
That's interesting, I've wondered before about the Matrox G200.
ETA: (reviewing the thread) man, Imageshack really did a number on the legacy internet.
Reply 686 of 864, by noshutdown
it would surely run, but can also depend on os and driver version. i think g200's driver had never been very stable till the end, although slightly better than s3 savage3.
Reply 687 of 864, by MrMateczko
Modern PC, Windows 98 SE, and not so modern GPUs 😜
Reply 688 of 864, by Baoran
I have heard people saying in the forums many times that Geforce MX4000 is a really bad card.
I have had Geforce 2 MX in my P3 1000Mhz retro pc for a while now and I decided to try MX4000 card that I got for free last year for the first time. Both cards are passively cooled so no noise and both are agp cards.
3dmark01 score for Gerforce 2 MX: 2438
3dmark01 score for Geforce MX4000: 3277
Which one would you keep in the system?
Reply 689 of 864, by KT7AGuy
Neither. Get a Voodoo 3 3000 AGP for compatibility or a GF4 Ti4200 for performance. Even a GF3 Ti200 would be a major upgrade.
(I suppose if I had to choose, I would keep the MX4000)
Reply 690 of 864, by Baoran
I think voodoo 3 would be bit redundant because the pc already has dual voodoo 2 cards, so the reason for trying to find a good nvidia card to complement the voodoo 2 cards was to keep dos compatibility while getting something faster for bit newer directx games.
My voodoo 2 SLI only got 888 points in 3dmark01 on that system.
Reply 691 of 864, by KT7AGuy
Aha! I wasn't aware that you had Voodoo 2 cards in SLI. You're right; that makes a Voodoo 3 redundant.
The MX4000 is better than your GeForce 2 MX card. However, it's still pretty weak and won't take full advantage of your 1ghz CPU. In this case, I recommend one of these instead, ranked from low-to-high performance:
GeForce 3 Ti200
GeForce 4 MX460
GeForce 3
Geforce 4 Ti4200
Prices on these cards are still reasonable.
This video may interest you:
Why did nobody buy the GeForce4 MX 460?
https://www.youtube.com/watch?v=_qWvc94DjJE
Also, if your primary interest is DOS compatibility, then check out this spreadsheet:
https://gona.mactar.hu/DOS_TESTS/
Reply 692 of 864, by Standard Def Steve
Integrated graphics: Sandy Bridge vs Haswell
Haswell is only 2 generations ahead of Sandy Bridge, but the difference in IGP performance is absolutely MASSIVE!
i7-4790 (Haswell) 3DMark01:
The attachment i7-4790 IGP 3D01.png is no longer available
i7-2600 (Sandy Bridge) 3DMark01:
The attachment i7-2600 IGP 3D01.PNG is no longer available
Haswell 3DMark2005:
The attachment i7-4790 IGP 3D05.PNG is no longer available
Sandy 3DMark2005:
The attachment i7-2600 IGP 3D05.PNG is no longer available
"A little sign-in here, a touch of WiFi there..."
Reply 693 of 864, by SW-SSG
Less massive as if you were to check the HD 3000 IGP with 12 execution units, for example in the i7-2600K. The i7-2600 and most of the other desktop Sandy Bridge chips use the 6-EU HD 2000.
Reply 694 of 864, by VooDooMan
System specs:
- ECS P6S5AT with SiS635T chipset
- Pentium III-S 1400 MHZ Tualatin (SL6BY).
- 512 MB DDR RAM 2-2-2-6
- Win98SE (Version 4.10, Build: 2222) with the latest service pack (SP.2.1b).
- Direct X 8.1.( 4.08.01.0901).
- SiS AGP GART Driver 1.07
GeForce 4 Ti 4600 128MB (44.03)
GeForce 6 6800 GT 256MB (81.98)
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 695 of 864, by Standard Def Steve
That is probably one of the highest scores I've seen for a stock-clocked PIII! Any chance you could overclock the CPU to 1575MHz? I'd love to see how that 635T board stacks up against my carefully tuned QDI board clock-for-clock. 😁
EDIT: Forgot to mention that I overclocked my 6800GT to 385/540 to hit my score.
Reply 696 of 864, by Baoran
EDIT: Forgot to mention that I overclocked my 6800GT to 385/540 to achieve that score.
Wouldn't P3 cpu be the bottleneck with such a new video card?
Reply 697 of 864, by VooDooMan
NO PROBLEM! 😁 I will do that today 😀 All of my SL6BY do 150 FSB at ease without adding voltage so no worries 😉 The problem for me is to find a good batch that will do 166 FSB... Then this motherboard with DDR 333 at 2-2-2-6 and the correct AGP divider will turn into real monster ;P
EDIT: Please notice, there is almost no difference between 6 6800 GT 256MB (81.98) and 5950 Ultra (44.03) on this mobo when 5 FX is on 150 FSB:
Yes, it is pointless to use such a powerful video card with this CPU, I installed it only to check the benchmark results. What holds this GPU( on this config) even more is the drivers... 44.03 are much faster than 81.89. Personally I think that Ti 4600 is the perfect match for Tualatin 1400 MHz 😉 I had 2 builds like that - one on ASUSU TUSL2C, and one on ABIT VH6T, but now that I've discovered that both of those motherboards suck in comparison to ECS P6S5AT I want to make some changes 😜
Reply 698 of 864, by VooDooMan
Here are the results 😉
SL6BY@150 FSB, GeForce 6800 GT Default CLOCKS (81.98)
SL6BY@150 FSB, GeForce 6800 GT OC 385/540 (81.89)
I must admit that you have WON this time! 😉 But there are reasons why I've lost:
1 thing is that my ram runs at CL2,5 your is CL2 ;P
2 thing you did your test on WinXP, I did on Windows98se 😉
To make this battle "fair" I have to find better RAM and install WindowsXP 😀 but this is going to take some time...
When it comes to lowering CAS latency, I assume I could score around 200 points more at CL2 😉
I made a test some time ago: I checked the results on CL2 vs CL2,5 using Ti4600 - the difference was slightly over 100 points. In this case 6800 GT is much faster than ti4600 so i expect around 200 points more at 2-2-2-6 but I might be wrong. Still I hope that one day I will be able to alter tRAS to set it to 5 with appropriate memories 😀
I have no idea what difference in performance switching from Win98 to XP would make with 6800 GT...
Reply 699 of 864, by Standard Def Steve
That's awesome. Thanks for redoing the benchmark at 1575MHz. No doubt you're going to beat my score once you get CL2 memory. And yeah, the 6800GT is definitely more of an XP-focused card, so you'll probably gain a bit from that, too.
And here I thought no one would even come close to challenging my DDR Tualatin 3DMark scores. 😀
