First post, by mastergamma12
So I decided to put together a Pentium III Rig with a Asus P3C-E and a Tualatin 1.4GHZ P3
Full Specs
Intel Pentium III-S 1.4GHZ Tualatin
Asus P3C-E
512MB PC800 ECC 45ns RDRAM
3DFX Voodoo5 5500
Creative Sound Blaster AWE64 Gold
Creative Sound Blaster Audigy 2 ZS
Kingston 10/100 Ethernet card
Pioneer DVD Burner.
WD Caviar SE 80 GB 7200RPM
500W PC Power and Cooling MKIII
Viewsonic PF790
Chieftec Dragon
file.php?mode=view&id=96715
file.php?mode=view&id=96716
file.php?mode=view&id=96717
    1.03 MiB
    394.33 KiB
    1.29 MiB
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 2 of 50, by Ponjiayulady
Great! I also have an ASUS P3C-D motherboard with dual P3 1Ghz on it
It’s an i820 board fitted with rambus RDRAM
854.21 KiB
241.42 KiB
317.2 KiB
304.88 KiB
Reply 4 of 50, by mastergamma12
Ponjiayulady wrote:
Great! I also have an ASUS P3C-D motherboard with dual P3 1Ghz on it It’s an i820 board fitted with rambus RDRAM […]
Wait is that a 3 slot 820 board?
Apparently those were supposed to be very buggy?
Reply 5 of 50, by Ponjiayulady
Do you mean i820 MTH bug?
That problem comes with i820 board using SDRAM,like asus P3C-2000 or Intel CC820
P3C-D is a single channel RDRAM board,so 3 memory slot is acceptable, unlike i840 chipset features dual channel must use all 4 slot
Reply 6 of 50, by mastergamma12
Ponjiayulady wrote:
Do you mean i820 MTH bug? That problem comes with i820 board using SDRAM,like asus P3C-2000 or Intel CC820 P3C-D is a single cha […]
Not the MTH bug, apparently Intel recalled RDRAM i820 boards with 3 RIMM slots due to interference or noise issues or something like that.
https://www.anandtech.com/show/461/7
Reply 7 of 50, by greasemonkey90s
too bad i cant get my asus p3c-d going tried everything and it was new open box. i suspect corrupted bios maybe just get cpu fan no post.
Reply 8 of 50, by greasemonkey90s
i thought it was the first rev of those that had the issue.
Reply 9 of 50, by mastergamma12
Here's an updated pic
I decided to move my Voodoo4 4500, and Live and AWE64 Gold into the rig
Reply 10 of 50, by chinny22
Socket P3's are boring to me, Slot 1 is were the action is... accept with RAMBUS that makes them cool.
But man, duel Slot1 AND RAMBUS... Another item goes on my wish list!
Reply 11 of 50, by matze79
OR840 dual coppermine with Rambus ?
Independant Ram Access for both CPU's so SMP can utilize Memory Bandwith.
Reply 12 of 50, by NostalgicAslinger
The PIII-S 1400 is the nicest S370 CPU and the only CPU that I prefer for this Socket. For all other like coppermines, I prefer the Slot 1.
Reply 13 of 50, by mastergamma12
I upgraded the 30GB Quantum potato I was using to a 80GB WD Caviar SE.
Crazy how much faster replacing that drive made the whole system.
Reply 14 of 50, by Katmai500
The side-mounted fan made me do a double-take. I was shocked that ASUS made a Socket 370 i820 board, but upon closer inspection I saw the slotket adapter. That's a really cool build for sure.
Slots are where it's at, but the Tualatin gets an exception since it's the top dog Pentium III. Those ASUS i820 boards are known to be unreliable. It's nice that yours is still working. I have an Intel i820 board, but it won't accept a Tualatin with the stock BIOS. 😢
Reply 15 of 50, by mastergamma12
The system was a PITA to set up, a real major one and when I first got the board, I thought it was dead until I found out that the power cable for the button wasn't in the right location because the system would turn on but not post period, then there was the headache of this Voodoo not working unless it's in the exact right location, then the GART driver not working until DX8 was installed, then I need to reboot the system after initial post or the rdram runs at 266mhz instead of 400mhz oh and the jumper free mode doesn't work.
But in the end, it seems to be fine and the board does deliver 1.45v to the cpu.
Reply 16 of 50, by ODwilly
Lovely system! I would recommend ditching that power supply ASAP. I have a 300 and a 500watt variant and they are absolutely filled to the brim with Fuhgyuu caps. They both seem to work alright but the 12v rail on the 500 is super weak and almost out of spec.
Reply 17 of 50, by mastergamma12
I've got a Thermaltake 430W with 30amps on the 5v rail.
Besides that, I've got nothing.
Reply 18 of 50, by ODwilly
That will work just fine actually, only need to worry about having a massive 5v rail on Athlon XP stuff 😀 just hate to see that PSU blow and take any of that hardware out. Could always recap the Chinese one at some point, mine seemed to be half decent at least.
Reply 19 of 50, by mastergamma12
It came in this case when I originally found it with a Biostar Slot A board with a Bunch of bloated caps.
IIRC that board still works but I'm never going to recap again, tried to recap 3 caps on a X48BT2 and killed it which is why I got a EVGA 790I FTW
ATM I'm using my Xp rig in my sig at that desk so when I get the chance, i'll consider swapping in the Thermaltake
