How about a MR-BIOS ROM file repository?
Reply 81 of 553, by Cyrix200+
I was digging through some boxes of junk I bought in the last few years, and I found this MR BIOS chip.
I have a MiniPro, but how do I find the correct chip type without removing the sticker?
Print on the bottom says 7138179BBA PHILIPPINES UX 50
1982 to 2001
Reply 83 of 553, by Cyrix200+
keropi wrote:
read it as generic 27C512 it should do the trick
So the software doesn't have a generic 27C512 option. I had tried a few already, but those didn't work. Then I selected OKI MSM27C512 and it worked!
Seems to be the "MR BIOS (tm) Copyright (c) 1992, Microid Research Ver V1.28 Port OPTI33" (Not sure if the 33 is part of the string) dated 01/15/92
1982 to 2001
Reply 84 of 553, by keropi
a trick to remember, chose whatever 27C512 chip you want but uncheck the "Check ID" tickbox on lower left corner of the program - then it will work
Basically the programmer won't check if it's a TI, OKI, AMD, whatever manufacturer and just dump the data
Reply 85 of 553, by rmay635703
I had always hoped for bios upgrades for name brand machines like the Tandy 1000 Rex or ast advantage adventure 4/66d
Ah well
Reply 86 of 553, by Moogle!
Aren't 386 BIOSes usually 32K?
You may to dump it as a 27c256, using the above mentioned methods. Wouldn't hurt to try both, I don't think.
Reply 87 of 553, by bjwil1991
Depends on the motherboard. Some were 64KB in size, others were 32KB.
Reply 88 of 553, by maxtherabbit
what's the rundown on >502MB support with Mr BIOS? did the 386 BIOSes have any translation support?
Reply 89 of 553, by Hinoserm
Signed up specifically to post this since I wasn't sure how to share the info otherwise.
Not sure if this one has already been found, but I recently found a MR BIOS chip on a motherboard marked SM 486-50USC. This board has a UMC UM82C491F chipset. The MR BIOS ROM chip is hand-marked 1150USC. The boot screen shows it to be MR BIOS V1.50.
You can grab a copy from the URL below. I would suggest if possible someone set up a mirror or upload it to the relevant archive. Included in the zip file are .bin and .hex files as well as photos of the board and chip. The chip is some version of 27c512.
http://otis.io/misc/mrbios_um82c492f_1150usc.zip
Reply 90 of 553, by keropi
Hinoserm wrote:
Signed up specifically to post this since I wasn't sure how to share the info otherwise. […]
mirrored the bios file locally
Reply 91 of 553, by Black6spdZ
Miasmark wrote:
I believe the Spectra Utilities disk contains most of the socket 5/7 bioses. and award bioses http://www.vogonsdrivers.com/getfi […]
http://www.vogonsdrivers.com/getfile.php?file … &menustate=54,0
I can't tell exactly which one is which since they are listed by numbers. likely have to boot the "Install disk" to see if the cd has a bios first. then you use the utility in windows to copy it to the floppy and then boot the floppy again to use it. Tested on a PB 640 and Advanced EV motherboard and both ended up with MR BIOS 3.46.
Im also curious what the differnce in the different versions of the disk are. since I have V1 of the cd.
Do you know what the Windows CD installer renames the bios image to before it copies it to the diskette? I cannot get the setup to work through an XP VM and USB floppy. I know the Mr Bios filename for my particular mobo "PB 680 Orlando" but it wont see the floppy correctly to transfer it over.
Reply 92 of 553, by obitus1990
Does anyone have an MR-BIOS for the Contaq 82C596A chipset for 486 motherboards?
Reply 93 of 553, by appiah4
I guess this is the best place to ask; I am trying to diagnose an Octek 486 board with a MR. BIOS. I am using a Diagnose Card, but I can't seem to locate the error codes for MR. BIOS anywhere. Does anyone have these?
Reply 94 of 553, by Cyrix200+
This should be the codes: http://www.bioscentral.com/postcodes/microidmrbios.htm
1982 to 2001
Reply 95 of 553, by appiah4
Thanks, I hope I can fix the issue here.
Reply 97 of 553, by dionb
Quick bump to confirm the Opti 82C495sx BIOS works beautifully on my "VESA Bus 495SX" board, which is either a See-Thru Data Systems STO 98-5VL, Auva CAM33-Px, J-Mark OPTI-495SX 3/486WB or DataExpert OPTI-495SX-2VL.
In any event, it previously had some kind of BIOS bug stopping it from booting into any device (POST and AMIBIOS setup went fine), after flashing MRBIOS that problem was gone and all the MRBIOS glory was revealed to me.
Reply 98 of 553, by cyclone3d
Here is an archived page that has at least some of the mr bios (esupport) documentation available other than what they currently have:
Some of the listed files are there, others aren't.
http://web.archive.org/web/20040507024044/htt … chsupport/docs/
Archived utilities:
http://web.archive.org/web/20011110055952/htt … os/mrbutils.htm
Archived specs page:
http://web.archive.org/web/20011007025808/htt … om/mr_spec.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 99 of 553, by Cyrix200+
I am looking for the 'C&T NEAT + EMS' MR BIOS. Has anybody ever seen it?
1982 to 2001
