dgVoodoo 2 for DirectX 11
Reply 3900 of 3949, by KainXVIII
Buggy shadows in Escape from Monkey Island with latest version (even without resolution forcing)..
523.07 KiB
Reply 3901 of 3949, by Srtest
Hello.
Using latest wip (switching to the official ver doesn't help), I get this white garbage in Vampire the Masquerade - Redemption (also effecting in-game rendering) whenever I use dgvoodoo. I can get the game to work without it only that some time ago I had much better results with using it and using the driver straight-up doesn't work that good and sometimes not at all. This happens when I use 16 bit texture bit depth because 32 bit doesn't work at all with dgvoodoo.
I'm playing on an AMD R9 380 with driver ver 19.2 and the only thing inside dgvoodoo which helps technically but not really as the framerate is horrible is switching to warp on the driver level. I have tried any config possible and it doesn't change anything about this (including in the amd driver).
    460.56 KiB
Reply 3904 of 3949, by antrad
I have a weird problem with Escape From Monkey Island with version 2.55.4. When I force resolution to 1280x960 and set centered scaling the framerate drops down to 36. It's nothing game breaking, but it's weird. I have not noticed any shadow issues though, but I only just got to the second island. (Windows 7, AMD card).
Reply 3905 of 3949, by Arklay
Force 21
with dgv2: "Could not initialize game!
without dgv2: black screen with music
inside f21 log
"It is not possible to create a D3D window with a hardware DirectDraw device. Check the mIsPrimary flag before calling D3DAppWindow.
InitializeRenderer() failed.
Display::Initialize() failed."
Dominant Species
with dgv2: only in game screen without menu, black bar in the left screen
without dgv2: only in game screen without menu, black bar in the left screen
insiede the ds log
"Initializing InputHandler
Initializing string localization code.
SetupSubsystems successful!
Renderer::Window() failed during CreateZBuffer() in file D:\Develop\common\renderer\renderer.cpp at line 976
Error = "Action not supported."
ouch! couldn't get hardware to initialize properly, try software
you know, many cards don't support hardware in a window...
selected 8bit palettized as the default texture format
ColorToValue() : Unknown bit depth (32)
Both games developed by Red Storm Interactive. These games share the same engine.
    66.03 KiB
    Dominant Species
    11.15 KiB
    Force 21
Reply 3906 of 3949, by ZellSF
ZellSF wrote:
Force 21 works perfectly with resolution forcing (usually limited to 800x600), but I had to hex edit the main exe to point to dgdraw.dll and rename dgVoodoo2's ddraw.dll to dgdraw.dll to get it to work.
Since Dominant Species uses the same engine, you'll have to do the same. Both those games definitely work with dgVoodoo.
Reply 3907 of 3949, by Arklay
Thanks, only F21 has a "problem" with a pink arrow, it can be removed with "GeForce FX 5700 Ultra" setting. Fast Video Memory Access has been selected for the ati white textures bug.
    55.59 KiB
    341.05 KiB
    dp ok
    270.49 KiB
    f21 pink arrow
Reply 3909 of 3949, by Shing
Thanks Dege for dgVoodoo. I just released my BF1942 graphics mod and dgVoodoo helped in many ways, so i was thinking about reporting these things.
Interestingly lightmaps are working on ships now. Idk what is causing it, never seen it from Geforce4 GPU/WinXP to modern GPU. But with dgVoodoo the lightmaps are loaded.
It removes stutters. As i modded the game i thought i ran into an engine limit, because it started to stutter. With dgVoodoo it's totally playable.
Also ReShade works perfectly now. The only bug is that it's crashing after 2 map loads. The game reloads everything when it loads a map and seems like dgVoodoo can't handle it too many times. Everything works perfectly if i load a second map, but at a third load it crashes.
Edit: Also everything is with the latest WIP59.1, but i think recent versions all worked in the same way.
Reply 3912 of 3949, by batterymandark
RoyBatty wrote:
DX10 Support would actually be great for Bioshock and STALKER: Clear Sky since microsoft broke it not long after those games released.
I indeed also is a bit confused by that? if you mean broken as in performance problem , than i can't clarify that, but DirectX 10 is supported just fine, same with Crysis in DirectX10, its runs fine.
in Windows 10 from my side at least.
Reply 3918 of 3949, by antrad
Is there a way to limit what resolutions a game can have available ?
I am playing Claw and it runs at 640x480. It has a cheat code to increase resolution, but I have to enter that cheat code several times until I get to a resolution I want. I would like to make the game think it only has 640x480 and 1024x768 available, so it changes to 1024x768 the first time I enter the cheat code.
