Reply 2100 of 3184, by shock__
Updated BOM (formating is correct in the .txt ... the code tag doesn't do it proper justice)
Also ... 2 generations of prototypes + current RC: https://i.imgur.com/8BXtlUC.jpg
ARGUS Release Candidate Bill of materials
Capacitors ceramic:
Part Value Package Note
C0 100nF SMD 0805
C1 100nF SMD 0805
C2 100nF SMD 0805
C3 100nF SMD 0805
C4 100nF SMD 0805
C5 100nF SMD 0805
C6 100nF SMD 0805
C7 100nF SMD 0805
C8 100nF SMD 0805
C9 100nF SMD 0805
C10 100nF SMD 0805
C11 100nF SMD 0805
C12 100nF SMD 0805
C13 100nF SMD 0805
C14 100nF SMD 0805
C15A 22pF SMD 0805
C15B 22pF SMD 0805
C16 100nF SMD 0805
C16A 22pF SMD 0805
C16B 22pF SMD 0805
C17 100nF SMD 0805
C18 100nF SMD 0805
C20 100nF SMD 0805
C22 100nF SMD 0805
C30 100nF SMD 0805
C31 100nF SMD 0805
C32 100nF SMD 0805
C33 100nF SMD 0805
C40 100nF SMD 0805
C41 100nF SMD 0805
C42 100nF SMD 0805
C60 100nF SMD 0805
C61 22pF SMD 0805
C62 22pF SMD 0805
C63 470pF SMD 0805
C64 470pF SMD 0805
C71 470pF SMD 0805
C73 470pF SMD 0805
C80A 6.8nF SMD 0805
C80B 6.8nF SMD 0805
C81A 6.8nF SMD 0805
C81B 6.8nF SMD 0805
C82A 6.8nF SMD 0805
C82B 6.8nF SMD 0805
C83A 6.8nF SMD 0805
C83B 6.8nF SMD 0805
C84 1nF SMD 0805
C85 1nF SMD 0805
C86 100nF SMD 0805
C93 100nF SMD 0805
C706 2.2uF SMD 0805
C707 2.2uF SMD 0805
C708 2.2uF SMD 0805
C709 2.2uF SMD 0805
C710 2.2uF SMD 0805
C711 2.2uF SMD 0805
Show last 144 lines
C712     2.2uF            			 SMD 0805
C713 2.2uF SMD 0805
C714 2.2uF SMD 0805
C715 2.2uF SMD 0805
C716 100nF SMD 0805
CA1 100nF SMD 0805
CA2 100nF SMD 0805
* Ratings shouldn't be lower than 35V
Capacitors electrolytic:
C200 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter**
C703 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C704 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C717 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C718 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C719 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C720 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter**
C721 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C722 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C723 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C724 10uF, 16V* Through Hole 2.5mm Pin distance, 6mm diameter**
C725 10uF, 35V* Through Hole 2.5mm Pin distance, 6mm diameter**
* Voltage ratings are minimums, personally I used 50V capacitors for all.
** A reasonable maximum height is 8mm when intending to use a daughterboard, otherwise virtually any height goes
Connectors:
SIMM 72 Pin SIMM connector, 90°, 45° or 0° i.e. AMP 73824862 (tested)
J1 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543N
J2 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543N
J3 3.5mm Audio Jack Stereo raised i.e. CUI SJ1-3543N
P8 15 Pin female SUB-D Print
MPC 1X04, 90° Pinheader 2.54mm
P45 1X04, 90° Pinheader 2.54mm
Resistors:
R1 10K SMD 0805
R2 10K SMD 0805
R3 10K SMD 0805
R4 10K SMD 0805
R6 10K SMD 0805
R7 10K SMD 0805
R8 10K SMD 0805
R9 10K SMD 0805
R10 61.9K SMD 0805
R11 10K SMD 0805
R12 10K SMD 0805
R13A 10K / nc SMD 0805 Refer to silkscreen or note for U31
R13B 10K SMD 0805
R13C 0 / nc SMD 0805 Refer to silkscreen or note for U31
R14 10K SMD 0805
R15 10K SMD 0805
R16 10K SMD 0805
R17 0 SMD 0805
R18 0 SMD 0805
R40 200 SMD 0805
R41 nc SMD 0805 not populated
R52 5.1K SMD 0805
R53 5.1K SMD 0805
R54 5.1K SMD 0805
R55 5.1K SMD 0805
R60 5.1K SMD 0805
R61 22K SMD 0805
R62 390 SMD 0805
R63 10K SMD 0805
R64 5.1K SMD 0805
R65 22K SMD 0805
R66 390 SMD 0805
R67 10K SMD 0805
R70 10K SMD 0805
R71 20K SMD 0805
R72 10K SMD 0805
R73 20K SMD 0805
R74 75 SMD 0805
R75 20K SMD 0805
R76 75 SMD 0805
R77 20K SMD 0805
R80 2.2K SMD 0805
R81 2.2K SMD 0805
R82 2.2K SMD 0805
R83 2.2K SMD 0805
R84 200 SMD 0805
R85 200 SMD 0805
R600 5.1K SMD 0805
R602 5.1K SMD 0805
R605 5.1K SMD 0805
R606 5.1K SMD 0805
R607 5.1K SMD 0805
R608 5.1K SMD 0805
R609 10K SMD 0805
R610 5.1K SMD 0805
R611 5.1K SMD 0805
R612 0 SMD 0805
R614 0 SMD 0805
R615 0 SMD 0805
R616 nc SMD 0805 not populated
R617 nc SMD 0805 not populated
R618 nc SMD 0805 not populated
R619 nc SMD 0805 not populated
R620 nc / 0 SMD 0805 See schematic. Default: not populated
* all resistors 1/8W (except R620)
Integrated circuits:
U0 DRAM 256K*16 or 1024K*16 (70ns or less) SO40 / SO42 i.e. HY514260BJC-60 (optional Socket: i.e. AMP 3-822265-2) or HY5118160JC-70
U1 DRAM 256K*16 or 1024K*16 (70ns or less) SO40 / SO42 i.e. HY514260BJC-60 (optional Socket: i.e. AMP 3-822265-2) or HY5118160JC-70
U10 AM78C201AKC QFP160
U30 AT93C66SC SO8
U31 IW78C21M1 / 29F800 (70ns or less) SO44 Socket optionally supported (i.e. Yamaichi IC179Z-44)*
U32 74F373DW SO20
U33 74F373DW SO20
U40 74F32D SO14
U60 TL082C SO8
U70 MS6308 SO8
* alternatively one can solder 2x 2x25 1.27mm SMD female headers (i.e. 20021321-00050T4LF) onto the elongated pads (spanning U31 and U31EX), for a future daughterboard
set R13A and R13C accordingly (IW78C21M1 -> R13A = nc, R13C = 0)
(29F800 -> R13A = 10k, R13C = nc)
Voltage regulators:
U20 7805 (1A or 3A) TO-220
U22 7905 (1A) TO-220
Oscillators:
X17 24.576MHz HC49/S
X18 16.9344MHz HC49/S
Connectors optional:
X1 2X31 Pinheader 2.54mm
X2 2X18 Pinheader 2.54mm
CON 1X02 Pinheader 2.54mm
IW 1X02 Pinheader 2.54mm
JP8 1X02 Pinheader 2.54mm
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 2101 of 3184, by matze79
i still found no way of disabling FM Emulation without Soundblaster Support, 😒
it would be nice to retain Digital Output and using my Prototype OPL2 Daughter board on Argus Header.
I will order testing boards soon 😀
Reply 2102 of 3184, by shock__
Keep us updated 😀
Any preview shots yet?
[Z?]
Reply 2103 of 3184, by 640K!enough
I guess they made the assumption that a person using a device with an FM synthesizer would also have basic Sound Blaster digital audio support. It was probably a reasonable design decision at the time; it was mostly just real Ad Lib cards that didn't have both (and maybe some extra-cheap off-brand clones).
I haven't really looked into whether there is a way to get support for this combination. Have you looked through MESETUP.EXE to see if recent versions of Mega-Em can do what you're looking for? I'm not sure, but I don't think IWSBOS will knowingly do one without the other. There may still be some tricks we can use to get the behaviour you want. For instance, have you tried changing the I/O address for the FM emulation in IW.INI? Unless the emulation tools change the values in those registers or also use protected-mode trickery to trap port accesses, any address other than 388h should do the trick (even try 0). Even if that works, it isn't clear what happens if some software tries to access the OPL2 via 220h, Sound Blaster style; this is something that warrants testing.
If none of that works, there may be other ways, but it's worth experimenting with the easier methods first.
Also, you may be able to cut down on the glue logic needed to decode addresses by using the external device support provided by the InterWave. The only drawback to that is that it would preclude use of the external serial port (not that I expect that to work for S/PDIF support anyway), as you would re-assign one or more of those pins.
Reply 2104 of 3184, by 640K!enough
Trying to get the new, just-for-ARGUS ROM module done, I notice that there don't seem to be any 16 MiB (8M x 16) parallel flash ICs with access times of 70 ns or less (at least not via Digi-Key). As it is, it looks like a multi-chip solution will be required. I intended to have two footprints for flash, anyhow, but a single-chip design would likely have been a less expensive way to get to 16 MiB. Does anyone know of a part that would meet those requirements?
Reply 2105 of 3184, by cyclone3d
What about this:
http://www.macronix.com/en-us/products/NOR-Fl … 0Flash&n=PM1683
or this:
https://www.digikey.com/product-detail/en/mic … 0N3E-ND/4316650
Looks like mouser may have a good selection as well:
https://www.mouser.com/Semiconductors/Memory- … 1z0t6brZ1z0vhtu
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2106 of 3184, by matze79
I will show it when i got the drawing finished!
want to finish the PSG Board first, and PSG Addonboard 😀
Reply 2107 of 3184, by hard1k
I think this question has already been answered here, but let me try to put it another way 😀
As we'll probably produce a batch of custom metal brackets (or at least make them like Fagear did), maybe we still could swap the Line-Out jack for 2xRCA? PCB space allows for that as far as I see...
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 2108 of 3184, by shock__
Definitely not anymore at this point.
[Z?]
Reply 2110 of 3184, by shock__
And XLR is better than RCA.
Unless there's something severely broken/non functional the current design is final.
And yes, while the actual change to the schematic is trivial, the layout would have to be majorly rearranged. Spacing the electrolytic caps wasn't that easy already and we're talking about fractions of millimeters here.
[Z?]
Reply 2111 of 3184, by 640K!enough
cyclone3d wrote:
What about this: http://www.macronix.com/en-us/products/NOR-Fl … 0Flash&n=PM1683 […]
What about this:
or this:
At Digi-Key, many of those are not stocked items. Those that are available are often too slow. Mouser doesn't list the full access time, while Digi-Key usually does. Many of the Cypress parts, once you factor in the delay for page access, are over 90 ns; shock__ has already shown that that will cause problems.
The Micron part may be fast enough, so I will try to allow for that in the design, and we'll find out when we try it. I will try to allow that as an option, so that either configuration can be used. The design is progressing, and soon it will be time for layout and routing, by far the most tedious tasks for me.
Reply 2112 of 3184, by hard1k
Sorry! I thought that the Line Out has migrated to the upper jack (as it's labelled as X3 I've confused it with the former J3 what used to mean Line Out, but then I looked carefully at both prototype PCBs and got that you've just changed the labelling), that's why I thought that obviously there was plenty of space upwards... My mistake 😀
Moreover, now it's completely clear to me that the Vibra bracket from CT4170 should be compatible and all its ports labels should be right (upside down - Line In, Mic In, Line Out), shouldn't they? So now the only manipulation needed for the Vibra bracket is either to cut its metal "wing" or to drill a mounting hole in the ARGUS PCB, correct?
AWE64 Legacy
Reply 2113 of 3184, by dogchainx
Very nice progress of the project! I've been MIA while my house is finishing being built, so completely forgot about this until today.
Excited to see what the next couple of months brings about!
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 2114 of 3184, by matze79
Today i recieved a Email from Digikey.
IC FLASH 8M PARALLEL 44SOP is EOL.
MX29F800CBMI-70G
Seems its buyable until 04/01/2020.
Reply 2115 of 3184, by 640K!enough
matze79 wrote:
Today i recieved a Email from Digikey. […]
MX29F800CBMI-70G
There is a notice on the Macronix Web site also. It seems that their (sole?) supplier is discontinuing a number of SOP packages and one PLCC. Still, we are likely to find suitable ICs available for the time that we need them, and the original masked ROM is still available for purchase.
For anyone sourcing flash ICs from eBay, etc., just make sure they have an access time of 70 ns or lower.
This notice is not enough of a problem to prompt any layout changes, as far as I'm concerned. We'll be able to source the parts we need. Besides, trying to accommodate another package on the board at this point would create major headaches and a horrendous routing mess.
Reply 2116 of 3184, by shock__
Absolutely agree ... just because an IC is going EOL doesn't mean it's a problem to source them for a small run hobbyist project. Afterall the IW78C21M1 is EOL since almost 20 years at this point.
If we were talking on the scale of 1000s per week for the next few months, then it would be an issue 😜
Still - good eye, I probably wouldn't even have noticed.
[Z?]
Reply 2117 of 3184, by 640K!enough
Just thought I'd share a preliminary progress report on development of the new ROM module. This first version is a bit sloppy and will only support up to 4 MiB, since larger 5V flash ICs aren't available. Please excuse the rough routing; it's not one of my strengths, and it's rather late (actually, early now).
I'm not sure this has quite the right proportions to clear the SIMM, when an angled socket is used, but for a first test, it will do. I haven't decided if these are even worth producing, or if it makes more sense to wait until I complete it's more capable counterpart. In either case, a few renderings:
EDIT: Images removed.
Reply 2119 of 3184, by shock__
Great news from 640k!Enough - bad news from me.
After an intentional delay (I currently have an extremely interesting and rare machine around for repairs) an unintentional one has been added. Might sound silly, but my soldering iron actually broke (<random brand> 853D - great station, but part of the soldering iron is made from a horrible plastic that gets brittle over time, especially when exposed to high heat, when reworking 4+ layer boards as I've been doing the past week) and it will take 5 weeks to get a replacement. So unless you consider yourself able to solder the InterWave yourself, you'll have to wait an additional 5 weeks til your "Release Candidate" will get shipped.
If that's unacceptable to you, I can offer a refund.
[Z?]
