First post, by boroda
8bit ISA VGA card, based on ET3000AX. Make by Princeton Labs
same as this card -
http://ru.pc-history.com/wp-content/uploads/v … 40_isa-8bit.jpg
Visually has no damages. But in the DOS text mode, there is no color on the LCD monitor.
If launch any game - there is color, all ok.
Can card switches affect this? Or is it just for ega mode? Any other ideas?
Thanks.
Reply 1 of 8, by Grzyb
Yes, the switches/jumpers may be set wrong.
https://stason.org/TULARC/pc/graphics-cards/M … A-DESIGNER.html - this is another card based on ET3000, as you can see there's that JP1 jumper to select monochrome/color monitor
Also, see the attached stuff, notably VMODE.COM - it may come in handy
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 8, by boroda
Thanks. OFF-OFF-OFF-OFF and JP1 2-3 - same monochrome screen in motherboard setup and in any dos text mode...
I thing card in half-dead... In vga cable pin 12 was removed before...
Reply 3 of 8, by vlask
Card might be optimised for monochrome monitor in bios too. Seen few ISA cards that behaved same way.
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 4 of 8, by boroda
Sorry? Card bios optimised for mono?
Reply 5 of 8, by Jo22
Textmode is provided via BIOS/VGA BIOS routines during post, which do care for the jumper settings.
Perhaps your LCD screen is falsely beeing detected as a monochrome monitor then.
Normally, monochrome mode is activated if pin 12 of the VGA port is grounded.
However, it could also be enabled by mistake if the pin is connected to "something" else,
like that Serial Data feature (used by DDC), which modern VGA monitors have.
Re: Can't get color in Windows 3.1
Reply 6 of 8, by boroda
Jo22 wrote:
boroda wrote:
Thanks, but pin 12 has been removed(i wrote upper), and any graphic mode
running well, with color.
Reply 7 of 8, by Jo22
boroda wrote:
Hm. I see. Well, as a last resort, maybe changing (or erasing/re-programming) the BIOS chip could help.
Another ET3000 VGA BIOS may work better than the current one. 😐
For example, here's one for the ET3000AX model:
http://www.vgamuseum.info/index.php/cpu/item/ … -tseng-et3000ax
Edit: Since this is a colour issue, maybe the RAMDAC chip is to blame.
I recall older Linux distros having problems with certain RAMDACs, so you were forced to select the right one during installation.
Anyway, that's just an idea. Depending on the pinout, RAMDACs were interchangeable.
So unless the VGA BIOS in question was made for a specific model, you could try a different one and see if the issue persists.
Reply 8 of 8, by Grzyb
Unlikely.
RAMDAC is only important for modes greater than 8bpp, and for some time there were various cards based on the same chipset, but with different RAMDACs, eg. a basic model with 8bpp RAMDAC, and a premium model with hi-color RAMDAC.
So yes, it was important to know which RAMDAC a given card was using.
But in this case it's irrelevant, ET3000 can't into more than 8bpp anyway.
I still suspect it may be misconfiguration, and 4 DIP switches = 16 combinations, perfectly possible to try them all...
