Reply 140 of 187, by Predator99
Next ones are 2 board from this lot:
1st one is labeled "BAY 1000C" and comes with a Phoenix BIOS dated 04/20/88. I received it with the wire-fix, but it has still problems with the power supply and does not work. Maybe an easy fix.
The other one works perfectly and as far as I remember it looks exactly like the board that was installed in my 1st PC I worked so many years with:
