HWiNFO support of vintage hardware
Reply 20 of 786, by agent_x007
Only unusual stuff can get software a proper run for it's money 😁
Like you said red-ray, one core is active, while five are "greyed out".
Maybe it's because I think in terms of CPU-z (which shows only what OS uses).
I thought it was the most logical option (even if CPU has 5 other cores turned on).
Reply 21 of 786, by CuPid
P200 MMX on Matsonic MS-5025S.
I need a vacation.
Reply 22 of 786, by Mumak
A nice oldie, thanks Franck !
I see that I need to fix a few things in HWiNFO for this system.
Reply 23 of 786, by CuPid
A Cyrix 5x86-S 120 running at 100 MHz.
Enjoy !
I need a vacation.
Reply 24 of 786, by Mumak
Enjoy !
Thanks! Need to fix/adjust a few more things 😀
Reply 25 of 786, by Mumak
Message for @voodoo5_6k:
Unfortunately I cannot send PMs (apparently I'm too young at least on this forum to do so), so I cannot reply to your message and will to do so here.
Thanks very much for your report! That's really an outstanding GPU 😀
I have tried to fix some things, especially detection of the multiple VSA100 chips on one card. If my assumptions are correct that these chips work in Quad-SLI mode, my fix should report proper information. Please try this new build: www.hwinfo.com/beta/hwi32_611_3921.zip
and let me know the result including a new Debug File.
Thanks again!
Reply 26 of 786, by voodoo5_6k
Mumak wrote:
Message for @voodoo5_6k: […]
I have tried to fix some things, especially detection of the multiple VSA100 chips on one card. If my assumptions are correct that these chips work in Quad-SLI mode, my fix should report proper information. Please try this new build: http://www.hwinfo.com/beta/hwi32_611_3921.zip
Thanks again!
Hi Mumak,
You're welcome and thanks 😀
In regards to the VSA-100 chips. Yeah, they are in Quad-SLI, but they all are behind the PCI-to-PCI-bridge Hint HB-1 SE66. That's different to the 5500. Two VSA-100 can work directly (Master-Slave), but more of them required the bridge chip. Maybe that's making it difficult to detect them all.
I'll look into the new version as soon as possible and will report back to you!
END OF LINE.
Reply 27 of 786, by Mumak
voodoo5_6k wrote:
Hi Mumak, […]
Thanks again!
Hi Mumak,
Thanks for the information. I (thanks to Ray) just found that the version I posted above might not properly report the config. I will need to adjust this and release a new test version.
I will post it here in a few minutes.
Reply 28 of 786, by Mumak
@voodoo5_6k
And here's the new version: www.hwinfo.com/beta/hwi32_611_3922.zip
My aim is to detect the 4 x VSA-100 config and show it as such including full memory size.
Looking forward to the results...
Reply 29 of 786, by voodoo5_6k
Mumak wrote:
@voodoo5_6k And here's the new version: http://www.hwinfo.com/beta/hwi32_611_3922.zip My aim is to detect the 4 x VSA-100 config […]
@voodoo5_6k
@Mumak
I have tested it yesterday and PM'd you the results!
END OF LINE.
Reply 30 of 786, by Mumak
voodoo5_6k wrote:
@voodoo5_6k
@Mumak
Thanks for the new test and results!
Since only one VSA-100 appears on the PCI bus, I wanted this to show up as one device (card) with VSA-100 x 4. So I attempted to detect this universally via SLI configuration, but that didn't work out (seems like the SLI config is not provided as I expected it). So I added a workaround for this case. Please could you try again this build: www.hwinfo.com/beta/hwi32_611_3925.zip and let me know the results.
What I haven't been able to figure out yet is how to report fan speed on this mainboard... It looks like it has an ADM1025 chip, but that doesn't support monitoring fans and the LPC47M112 is quite tricky.
Reply 31 of 786, by Mumak
voodoo5_6k wrote:
@voodoo5_6k
@Mumak
And here just another build where I attempted to add fan speed monitoring of the SMSC LPC47M112: www.hwinfo.com/beta/hwi32_611_3926.zip
Reply 32 of 786, by voodoo5_6k
Mumak wrote:
voodoo5_6k wrote:
@voodoo5_6k
@Mumak
And here just another build where I attempted to add fan speed monitoring of the SMSC LPC47M112: http://www.hwinfo.com/beta/hwi32_611_3926.zip
Tested and results PM'd 😀
END OF LINE.
Reply 33 of 786, by Vynix
Have a report fresh from my P133 rig, in the hopes it'll be useful... (by the way, I had a hard time making this report, because my P133 is infuriatingly temperamental 😠 and LOOOOOVES to crash or randomly fail in often worrysome yet spectacular ways)
Without further ado:
Reply 34 of 786, by Mumak
Vynix wrote:
In the hopes that is going to be useful:
Thanks! Yes, it's useful, I haven't got such a report for pretty long time 😀
I see that SMBIOS DMI information is a bit messed up. Looks like the BIOS doesn't fill it properly and I need to workaround this.
What is the mainboard model, according to BIOS ID it should be Shuttle HOT-555A. Is that correct?
Reply 35 of 786, by Vynix
Yes that's the one, more specifically, it's a Shuttle HOT-555A Rev. 3.2, the one I have seems to have a few issues at the moment (such as random hardlocks and corruptions when using a PMMX... Oh well)
Reply 36 of 786, by agent_x007
i7 965, wrong name ?
The attachment HWINFO i7 965.png is no longer available
I added raport as well.
PS. 7800 GTX has 16ROPs and 24 Pixel Shaders.
Reply 37 of 786, by Mumak
agent_x007 wrote:
i7 965, wrong name ? […]
Thanks. That's because of Win98.
To identify a CPU HWiNFO doesn't rely on the CPU name string (which can be faked sometimes), but on certain factors. An since Win98 doesn't have MPS support, the number of cores is limited, which causes the mismatch.
I think that GPU parameters might be wrong because it's not properly initialized due to the driver lack.
Reply 38 of 786, by vutt
Tried on my w98SE rig.
It crashes. At CPU detection it seems.
I'm using latest beta BIOS so I can use higher clocked Coppermine CPUs
Yeah I'm running my 650Mhz(100FSB) P3 at 133FSB speed, but it have been rock stable over 4 months. So it can't be the issue.
Reply 39 of 786, by Mumak
vutt wrote:
Tried on my w98SE rig. It crashes. At CPU detection it seems. I'm using latest beta BIOS so I can use higher clocked Coppermine […]
Thanks. I think I found and fixed the problem.
Please try again with this build: www.hwinfo.com/beta/hwi32_613_3936.zip and let me know the result.
