First post, by tails
I'm finding that my build is being haunted by blue screens, rundll errors and scandisk saying that it's finding corrupt data and long file names. I've checked the ram and not found any issues and was wondering if it's becase I'm using a 250GB hdd. It's partitioned into three fat32 partitions of roughly 10GB, 111GB and 111GB. I've always installed on a freshly formatted 10GB partition and no other weird unofficial updates are being installed. Only the drivers for my hardware.
Reply 1 of 16, by derSammler
Windows 98 can not use hard disks larger than 128 GB. If it is larger, writing to anything past the 128 GB will cause a wrap-around and cause random data corruption.
Reply 2 of 16, by darry
https://msfn.org/board/topic/148706-max-size- … 8se-can-handle/
I personally use a SIL3114 based SATA controller and have installed this http://www.mdgx.com/files/BHDD31.ZIP from http://www.mdgx.com/upd98me.php for the updated utils .
I have a 500GB SATA drive with multiple <127GB partitions in use with no issues .
EDIT : The partition table was created with a Linux bootable CD or FreeDOS (not sure which) .
Reply 3 of 16, by tails
What's special about that particular SATA controller that Windows prefers to any type of on-board controller?
Reply 4 of 16, by mothergoose729
You can patch win9x to work with hard drives up to 2TB, but it isn't really worth it IMO. 128gb is an absolutely massive amount of space.
Reply 5 of 16, by tails
You're right. The only reason I was trying to use larger was to have all my retro PC software and drivers there and available for me on another partition rather than finding discs or constantly transfering files between PC's on USB flash drives.
Reply 6 of 16, by chinny22
You still cant do this with 128GB? Honest question as I do exactly this but don't even fill 128GB
Reply 7 of 16, by data9791
Is it possible to set larger drive to read only and use them to copy from?
Reply 8 of 16, by derSammler
There are bridge adapters that make hard disks read-only. But just by software, I'm not aware of any methods to do so.
Reply 9 of 16, by tails
I probably can. Just also wanted to use some of the hardware I have on hand
Reply 10 of 16, by darry
It's not really special, it is just one example of a controller that requires its own driver and does not use esdi_506.pdr .
esdi_506.pdr limitations are the root cause of the issue with drive size .
Reply 11 of 16, by foil_fresh
what about external usb drives using the nusb stack? i've got a 500gb external hdd which has 7 x 32gb FAT32 partitions and one big NTFS partition. will i have problems after the 4th partition where the size gets over the limit? i haven't noticed anything strange (yet) and i've swapped this drive between 5 computers, filling up about 180gb of it so far...
Reply 12 of 16, by chinny22
Problem is Win9x doesn't understand NTFS nativity.
You can get 3rd party programs, the read only versions can be free which may be enough for what your after anyway.
https://msfn.org/board/topic/110814-ntfs-supp … -in-win-98seme/
Reply 13 of 16, by foil_fresh
im keeping the ntfs partition for xp only so it never gets detected in win98 thus not an issue for me, just worried about the 7x32gb aspect.
edit: i will add that this is a usb 3.0 drive connecting via an NEC PCI USB 2.0 card, using NUSB 3.6 and the NEC drivers for the card. The disk driver is a standard driver from the 98se cd.
edit2: looks like i've fudged myself pretty hard, 22bit lba extends to external/removable media. there is a possibility things written past the 128th gigabyte will wrap around and write to the beginning of the disk (the partition with all my DOS games on it... uh oh. explains why i had so much trouble last night installing video drivers 😀
Reply 14 of 16, by SaxxonPike
I have used an external USB drive with Win98 without issues well over 128GB. My current setup uses a Pi and an SMBv1 share. I think it’s strictly a limitation with the onboard HDD controllers and BIOS at the time.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 15 of 16, by foil_fresh
do you recall if you filled up over 128gb?
Reply 16 of 16, by aazard
I only add this, as 128gb drives are starting to become "too small" for the mass market, and will "soon" be hard to locate
Research seems to say that to install Windows 98SE on HDD larger than 128gb:
- Make the first partition exactly 128gb (Phil has a video, well detailed. BUT IMHO, its easier to use a win2k or XP disk to format as fat32 and stop before installation)
- Install the Windows on it
- Apply a patch to access the whole HDD (I believe we are again "super hard" limited at 4tb)
- (Optional) Resize partition with 3rd party tools
Windows 98se "shouldnt" be able to see info past the 136gb "OS barrier" pre-patch, but as long as it "cant try to write to that area", you should avoid BSOD's at least
Recovered Mdgx files, info, readme, file: http://www.techtalk.cc/viewtopic.php?p=16873& … f8e5f4b6#p16873
Unofficial Windows 98 SE 48-bit LBA > 137 GB Hard Disk
ATA/IDE Improved Driver ESDI_506.PDR 4.10.2230 ReadMe
Unofficial Windows 98 SE 48-bit LBA > 137 GB Hard Disk ATA/IDE Improved Driver ESDI_506.PDR 4.10.2230 ReadMe in plain text (ASCII) format
Cached:
ATADRV98.EXE = http://www.techtalk.cc/download/file.php?id=9 … baef8dcf8e5f4b6
Aazard -
Mono Planar Mortal & Unascended Master
Retro Enthusiast & L3 Trouble Shooter
.... Getting old
