M-audio Audiophile 2496
First post, by MKT_Gundam
I got this card today.
Besides the use in profissional audio software, theres any use for basic win98 gaming?
Will be better than a typical C-Media CMI8738?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 18, by xjas
It will work fine for "basic gaming" in Win98, but it doesn't support any 'gamer' features like A3D, EAX, etc. or ANY DOS-mode compatibility whatsoever. For MIDI music, unless you connect an external synth, you're limited to either the MS GM/GS soundset or running a softsynth like the Yamaha S-YXG100 (which is what I use.) That said, the drivers are pretty good & have lots of options to configure.
It's actually a good choice for getting lossless digital audio out of a Win98 box, and the MIDI implimentation is really solid, as you'd expect.
Reply 2 of 18, by MKT_Gundam
Is this card problematic on VIA chipsets like the SB lives?
Did you use together with a ISA soundcard?
Reply 3 of 18, by xjas
I never had any issues with it in my KT266-based Athlon XP box.
Considering it's based on the Envy24, which is a VIA chip itself, you'd hope it'd play nicely.
Reply 4 of 18, by MKT_Gundam
Thanks. I plan use alongside a Sb32 with 8mb + vIa c3 cpu.
Will be my Xmas build! 🤣
Reply 5 of 18, by xjas
Nice, no reason it shouldn't work since AFAIK the M-Audio card doesn't use any "legacy" (DMA, etc.) resources.
I don't have an ISA slot in the PC I used it in, so I never tried.
Reply 6 of 18, by dionb
Have one of these in my retro room desktop PC, as I hate 3.5mm jacks and I only really use it for music. When it comes to that it does the job excellently, with sky-high SNR and zero troubles in either Linux (where it works out of the box) or Windows.
Reply 7 of 18, by gdjacobs
Some drivers support basic A3D and EAX through Sensaura's software emulation, but that's not really this card's forte.
Reply 8 of 18, by appiah4
IIRC it has no Windows 10 support?
Reply 9 of 18, by bristlehog
It worked for me in Windows 7 x64, so I see no reasons it wouldn't work in Windows 10.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 10 of 18, by appiah4
The Windows 7 x64 drivers no longer work with Windows 10 after the recent build updates.
Refer here for more: https://getsatisfaction.com/m-audio/topics/au … ver?full_site=1
Apparently some people had success with using ASIO4ALL drivers but that's less than ideal.
It sucks but it's unusable with a current Windows 10 build. With Windows 7 (and 8.x using 7 drivers) and Linux, it works perfectly though.
Reply 11 of 18, by gdjacobs
Driver signing issue?
Reply 12 of 18, by swaaye
Win10 >= 1903 broke a lot of drivers for some reason. I have a feeling I read somewhere that security features are the cause.
Reply 13 of 18, by appiah4
Too bad M-Audio does not give a shit about updating the Win7 driver. Like, at all.
Reply 14 of 18, by dionb
You can hardly blame M-Audio if upstream Via also dropped support for their entire audio products range after Win7.
Reply 15 of 18, by MKT_Gundam
gdjacobs wrote on 2019-12-05, 02:31:
Did you have theses drivers or the original cd?
The lastest driver on official site needs use direct x8.1.
Reply 17 of 18, by MKT_Gundam
gdjacobs wrote on 2020-01-02, 19:59:
Can you see if the Terratec DMX 6fire 24/96 drivers work?
https://www.techspot.com/drivers/driver/file/ … formation/1802/
The downlaod link sems dead for me.
I found this one:
https://www.solodrivers.com/en/driver/55828/S … -Fire-24-96-WDM
The drivre version is 5.4
Reply 18 of 18, by gdjacobs
Let me know how it goes. M-Audio also included Sensaura with their Revolution cards, but the 2496 was always meant for the home studio people.
