Reply 40 of 827, by vutt
WOW! That was fast!
Yes startup problem is fixed. HW info in my case is showing up correctly.
However it looks like it gets confused by my "SINTECHI HighSpeed SD to IDE" adapter. I'm running entire system off the SD card without physical HDD.
In benchmark section my Disk bench option is disabled. Rest of the benchmark runs well. It shows me results window. I was even able to use Save Report feature, but when I press "close" button I'm getting blue screen. Only Ctrl-Alt-Del helps.
I tried to turn on logging, but it appears that Benchmark feature does not log anything. Or because disc buffers were not saved on disk before with soft reset.
Sensors section works fine as well.
I have abused my win98 a lot over past 4-5 months. A lot of software and hardware installs and removals. So some blue screens might be natural. I'm planning at some point to do fresh install. So I will revisit this issue then again.
