First post, by FlorianKeckeis
Hi everybody!! 😀
I've got a little problem with configuring some DOS-games. For example Mortal Kombat. I do my settings in the setup, but it doesn't save them. That also ocurs with other games.
I always get the message in the status-window of DOSBox, that the creation of a file (also with filename) failed. I also suppose to know the reason: The folder that contains my DOS-games has the "read-only" attribute. But I cannot remove it. I allready tried to create other folders. Each folder I create new gets the "read-only"-attribute. It seems to be a windows-standard-procedure to give each folder the "read-only"attribute. Is this the cause for my unability to save configs? What can I do against that? I think this problem can und must be solved.
OK, that's it for the first. 😀
Helping me solving this problem would be a really big favour. 😀)
The best greetings
Flo
Reply 1 of 8, by Lofty
Why can't you remove the read-only attribute from the folder?
*thinks*...Are you using an admin account, or a user account on windows?
Reply 3 of 8, by FlorianKeckeis
Hi everybody!!
I also get the following message: "Warning: file creation failed [filename].
I also suppose to know the reason: The folder that contains my DOS-games has the "read-only" attribute. But I cannot remove it. I tried it in Windows Explorer and with the "Attrib" command. I realized, that each folder on my PC and also each new created folder gets the "read only" attribute. I'm also logged in as Admin on my PC. So, what can I do? Or do you know another reason for my unability to save configurations?
OK, that's it.
Please help me.
The best greetings
Flo
Reply 4 of 8, by wd
Rank DOSBox Author
DOSBox Author
Hm, not sure why your files get read-only always, but for mk1
you can just delete the hidden file cmos (without extension),
it will be recreated the next time you start the game.
Reply 5 of 8, by Lofty
There's no need for multiple threads about the same problem...
Reply 6 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
*merges*
Water flows down the stream
Reply 7 of 8, by FlorianKeckeis
Hi everybody!! 😀)
Maybe you remember my last two topics regarding problems with saving game-configs in DOSBox. Well, I've got some kind of a solution. Maybe, there are others with similar probs and My solution helps. Here it is:
It's easy: you've to find out the name of the file, that uses your game's setup to save the configuration. Delete it (uner windows, not under DOSBox). After deletion start DOSBox and the game / it's setup. In most cases a new file with your desired config will be created.
OK, I hope it helps, but this fist-full of trials I made gave me a good impression.
The best greetings
Flo
Reply 8 of 8, by eL_PuSHeR
* Merged Again and thread title modified to reflect changes *
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
