First post, by FlorianKeckeis
Hi everybody!! 😀
I've got a little problem with configuring some DOS-games. For example Mortal Kombat. I do my settings in the setup, but it doesn't save them. That also ocurs with other games.
I always get the message in the status-window of DOSBox, that the creation of a file (also with filename) failed. I also suppose to know the reason: The folder that contains my DOS-games has the "read-only" attribute. But I cannot remove it. I allready tried to create other folders. Each folder I create new gets the "read-only"-attribute. It seems to be a windows-standard-procedure to give each folder the "read-only"attribute. Is this the cause for my unability to save configs? What can I do against that? I think this problem can und must be solved.
OK, that's it for the first. 😀
Helping me solving this problem would be a really big favour. 😀)
The best greetings
Flo
