My 3DMark01 Mega Thread
Reply 720 of 838, by Carlos S. M.
(Reposted again due to an issue when trying to update my post)
Also benched my VIA C3 system (VIA EPIA M1000) with both the onboard S3 UniChrome (VIA CLE266) and a Radeon 9000 PRO PCI (Hercules)
Specs:
VIA C3 1 GHz (Nehemiah)
1 GB DDR 266
VIA EPIA M1000 (VIA CLE266 + VT8235)
S3 UniChrome/ATI Radeon 9000 Pro PCI
80 GB WD HDD
Windows XP Pro SP3
Reply 721 of 838, by Carlos S. M.
Tried 3DMark2001SE in one experiment rig running Windows 2000 Pro SP4
Core 2 Duo E8600 (stock/4 GHz)
Gigabyte GA-P35-DS4
8 GB DDR2 800 CL5
ATI Radeon HD 5870 (Sapphire Vapor-X)
2x 500 GB HDD
Reply 722 of 838, by MMX
Here is one of my oldie but hardworking systems 😊
A64 3400+ (S754) + GA-K8NS Pro 3D Mark 2001 SE (330) 21430
Reply 723 of 838, by MMX
And oldie but playful system 😊
P4 3,2 Northwood + P4P800 20694
Reply 724 of 838, by appiah4
Peculiar that you would get a 10% lower score than I did using just a X1950PRO on a Radeon 3700+ - this benchmark really scales with CPUs..
Reply 725 of 838, by MMX
Radeon 3700 it's quite rare CPU 😀 Also on your side is ClawHammmer, may be is better. And my RAM now is limited on 333MHz with boring timings. It just sucks 😠 I plan to fix it.
Reply 726 of 838, by MMX
Just recently i made some tests. I think 512Mb(400MHz) is much better for 3D Mark 2001 than 1,5Gb(333MHz)
Reply 727 of 838, by VooDooMan
ASRock 775-Dual VSTA @ Intel Core 2 Extreme (X6800) at 3075MHz and 2GB of DDR2 RAM testing Radeon HD 3850 AGP in 2001SE 3D Mark
I am pretty sure this card can do much better 😜
ECS P6S5AT (SiS 635T) 2001SE 3D MARK
- Tualatin-S 1400 MHz SL6BY (512 kb cache 133FSB)
- 1GB DDR266 RAM (CL 2-2-2-6)
- WINDOWS XP! - Direct X 9.0
GeForce 6800 GT
Radeon HD 3850 AGP
GeForce 4 Ti 4600
GeForce 5 FX 5950 ULTRA
Radeon 9800 PRO 128MB
GeForce 3 Ti 500
SiS Xabre 600
GeForce 2 ULTRA
GeForce 2 GTS
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 728 of 838, by Kamerat
Kamerat wrote:
Some overclocked Intel GMA action :lol: […]
Some overclocked Intel GMA action 🤣
Lenovo 3000 C100
Intel Pentium M 745A @ 2556MHz
Intel GMA 900 @ 400MHz
2GB PC6400 dual channel @ 284MHz DDR
Windows XP Pro SP3
file.php?id=14283
Used 5 years to improve the score by 107 points, notice the tighter memory timings (modded the SPD info on the RAM sticks to get CAS 3). 🤣
The attachment lenovo_3000_c100_3dmark2001_6811.PNG is no longer available
YouTube channel
Reply 729 of 838, by Standard Def Steve
Now that I'm running this beast of a PIII machine at 1628MHz, I thought I'd rebench my 9800 Pro. The results are spectacular!
PIII-S @ 1628MHz, 155FSB
2GB DDR @ 310MHz, 2-2-2-5
9800 Pro @ stock, Catalyst 4.12
X-Fi Platinum
QDI Advance 12T mobo, Via Apollo Pro266T chipset
WinXP Media Center 2005 SP3
The attachment PIII-1628, 9800Pro-3D01.png is no longer available
This thing will probably break 14K once I get my overclocked 6800GT back in! I'm currently using the 6800GT in an Athlon XP 3200+ machine I just picked up.
"A little sign-in here, a touch of WiFi there..."
Reply 730 of 838, by VooDooMan
12604 3D marks! Very impressive 😉 Could you also run that test with half the RAM and at stock CPU speed? 😜
Reply 731 of 838, by SPBHM
Celeron 2.1GHz and VIA P4M266 with OC, the IGP is not massively far from the Savage4 in which is based but I think it's slower.
The attachment celeron21_OC_3dmark01.JPG is no longer available
6150SE with OC, not really the fastest driver or anything, but it was kind of fun OCing this thing, I should have tried a little more for 8k.
The attachment 3dm01OC.JPG is no longer available
Reply 732 of 838, by Carlos S. M.
Benched the VIA Chrome 9 HC on the ASUS P5VD2-VM, the last VIA/S3 IGP for Intel platform
Stock CPU clock
The attachment chrome 9 hc 3dmark01.PNG is no longer available
Overclocked (board can't really overclock much)
The attachment chrome 9 hc 3dmark01 oc.PNG is no longer available
Reply 733 of 838, by ElementalChaos
Recent bench from "Pluto".
Specs are in my signature, but for posterity:
  • Pentium III 1400S, 133FSB
    Intel D815EEA (OEM board from a Dell Dimension 4100 flashed with Intel BIOS P10)
    256MB PC133 CL2
    GeForce4 Ti4200 AGP 8x (OC, 280MHz core, 570MHz memory)
    SB Live! 5.1
    Adaptec 39160 Ultra160 SCSI controller
The attachment 3dmark 2.png is no longer available
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 734 of 838, by dottoss
A recent Windows XP install on an AMD E-350 with integrated Radeon 6310. It seems to performs like a P3 of approx the same speed.
Reply 735 of 838, by Carlos S. M.
Benched my new Windows 2000 system:
Intel Core i7 930
ASUS P6T SE
12 GB DDR3 1333
ATI Radeon HD 5870
2x 500 GB HDD
Windows 2000 Pro SP4 with BWC Extended Kernel and Extended Core
4.3 GHz OC all core + HT:
The attachment i7 930 oc 3dmark01.PNG is no longer available
4.63 GHz OC only 2 cores enabled and no HT:
The attachment i7 930 ultra oc 3dmark01.PNG is no longer available
Reply 736 of 838, by Standard Def Steve
This cute little Optiplex has teeth! The performance is not bad at all for an OEM business box.
Core i5-4670 @ 3.6GHz
16GB DDR3-1600 9-9-9-24-1T
GTX 1650
Win7 Pro SP1
Very quiet and efficient too.
Reply 737 of 838, by Standard Def Steve
This is probably the most fun I’ve had with 3DMark01 since 2001. Here it is running on a 110" 4K screen. Despite the D-ILA projector not being designed for gaming, it has an incredibly quick pixel response time and great motion resolution. In fact, I don't think I've see such smooth, clear motion since running this benchmark on a CRT! I’m going to have to start bringing my games down here and running them on the HTPC!
Reply 738 of 838, by Carlos S. M.
Tested my new HD 3850 AGP from a trashpicked compaq.
Specs on tested system:
Pentium E5700
Asrock Conroe865PE
2 GB DDR 400 CL3
250 GB HDD
ATI Radeon HD 3850 AGP
Windows XP SP3
The attachment 3850agp 3dmark01.PNG is no longer available
Also did 3dmark03 and 06 as well
The attachment hd 3850 agp 3dmark03.PNG is no longer available
The attachment hd 3850 agp 3dmark06.PNG is no longer available
Bonus; Intel Q45 IGP (On Dell Optiplex 760)
The attachment Q45 3dmark2001se.PNG is no longer available
Reply 739 of 838, by appiah4
Rehoused my Athlon64 3700+ system and downgraded my dead X1950PRO to an X800XT PE. Pretty impressive score as far as I am concerned.
