Working on my "OpenGL Workstation" build. I'm building a machine around the HP Visualize fx10 NT (AGP Pro). After unsuccessfully trying to just order an HP Visualize workstation I decided to build my own.
This is all going in an InWin A500 case.
I got Noctua fans to replace all the regular fans, so I got a speed controller. Alseye a-100L(WR)
SuperMicro 370DE6 Dual Pentium P3 Socket 370 Motherboard
2x 1.0ghz P3's (I know I could have gone to 1.4 but I wanted to stick to 1.0)
4x 39L6JS0R-1G00 1GB 128X72 PC133 ECC REG SDRAM
2x Socket A - 370 - 462 - 7 Copper heatsink/fan Low Profile Dynatron Fan Blower
^Needed to get the clearance for the CPUs by the power supply. Still not sure about this case for this build.
Not retro:
Noctua NF-F12 PWM, Premium Quiet Fan, 4-Pin (120mm, Brown)
2 of Noctua NF-A6x25 PWM, Premium Quiet Fan, 4-Pin (60mm, Brown)
LM YN Motherboard Extension Wire Set (for slide out motherboard tray)
10x Winbond W9825G6KH-5 256mbit 200mhz SDRAM
5mm Lumex InspirationLEDs turquoise "comfort" LEDs (meant for hospital equipment)
BTW what those Lumex InspirationLEDs look like (they came out some time ago):
I want to build in an LED CPU meter that tracks both CPUs but also does different crawling animations, so I got two high density (128 pixel) LED strips to go in the 'divet' at the front of the inwin a500 case.
Is there a way to use [img] to make a smaller thumbnail? Thanks.
