gex85 wrote on 2020-02-04, 08:05:
You might want to go through this thread for ideas: Dual PIII-S Tualatin 1.4 GHz Success Stories
If I were you, I would try as many different RAM modules and graphics cards as possible.
As far as the CPUs are concerned, you probably have SL5XL (not SL6XL). Should be absolutely fine to use them in a dual CPU system.
many thanks. yes, mine are SL5XL. i have to assume ONLY sl6by supports dual CPU tech.
for mem issue, i've double checked , no mem repapping settings, and video shadow was disabled. i've checked many video on youtube, they only showed 3.6G. i can partially accept this, but suppermicro says this board supports 4G, if so, it should show 4G, not 3.6G, even OS is unable to use 4G, but that is OS's business.
