First post, by Joseph_Joestar
The attachment bracket.jpg is no longer available
These brackets are meant to be used to get digital audio OUT by connecting the relevant wires to the three corresponding pins (SPDIF_OUT, +5V and GND) on your sound card or motherboard.
My question is, can you instead get digital audio IN if you connect the SPDIF wire to the SPDIF_IN pin and leave GND and +5V as they were? The card in question is an Audigy2 ZS and the pinout is attached below.
Intended use case: I want to connect a PlayStation2 to the Audigy2 ZS via Toslink cable in order to record high quality gameplay audio.
The attachment ad_ext.jpg is no longer available
My retro builds
Reply 1 of 13, by Marmes
Interesting bracket, where did you find it? And the answer about spdif in may be no 🙁
Reply 2 of 13, by Doornkaat
Depends on the bracket.
The coaxial S/PDIF should be fine with a simple coaxial cable directly connected.
For the optical S/PDIF (TOSLINK) you'll need a connector that's capable of receiving an optical signal and turning it into an electrical signal. Usually this is done with a different jack, with a cheap audio out breakout board with only three wires I'm almost certain there'll be only an emitter present.
Reply 3 of 13, by Joseph_Joestar
Thanks for the clarification guys. Guess I'll have to look for a card with an optical audio in port. I initially wanted to get one of those Audigy2 ZS front panels, but they are impossible to find nowadays. Not for a reasonable price that is.
As for the bracket, it's from Aliexpress. Just search for "SPDIF bracket" on that site and it will pop up.
My retro builds
Reply 4 of 13, by Doornkaat
Any card with optical in and support for your OS will do. It's a digital signal so there shouldn't be any losses even on low end cards. I don't think you'll need to spend much. 😀
Reply 5 of 13, by imi
Joseph_Joestar wrote on 2020-02-22, 14:20:
any live drive front panel should work with the audigy too afaik.
Reply 6 of 13, by Joseph_Joestar
imi wrote on 2020-02-22, 14:36:
Interesting, I didn't realize that.
Is the 40-pin ribbon cable which connects the card to the panel always the same? I might be able to get an Audigy1 front panel for much less money.
My retro builds
Reply 7 of 13, by imi
actually, I'm not so sure anymore, I just read it before, but I just googled now and found a thread pointing out that the pinouts are indeed different, so while it would theoretically still work you'd need a custom cable for it.
this thread states that it should be compatible up to the normal Audigy: Audigy 1 -> Live! Drive IR
the Audigy 2 ZS uses a different one but it didn't work? idk all a bit confusing.
Reply 8 of 13, by The Serpent Rider
You can use X-Fi panel with Audigy 2 and vice-versa. Although external boxes for Audigy/Audigy 2/Audigy 4 Pro are more handy and cool.
Reply 10 of 13, by imi
careful though, the audigy and audigy 2 seem to be using different pinouts
Reply 11 of 13, by Wanderer
Hello all.
@Joseph_Joestar: as an option, you could use an optical-to-coaxial converter followed by a self-made cable with an RCA jack on one end and a 2-pin internal connector on the other end, attached to CD_SPDIF header. The signal will be availble via CD Digital channel in Windows mixer for both playback and recording. (That is, if optical source is PCM. Not sure what happens when there is an AC3/DTS stream and how to record it properly.)
HTH
Reply 12 of 13, by Joseph_Joestar
That's an interesting idea.
However, it looks like some PS2 games do use AC3 for cutscenes and such, so I'm going to play it safe and go with the front panel.
My retro builds
Reply 13 of 13, by Joseph_Joestar
Got a great deal on a Sound Blaster Live 5.1 and an Audigy1 front panel. I can confirm that these two work together perfectly.
It's amazing how much clarity the optical output can get out of PlayStation2 games. Audacity reports no background noise whatsoever, so I'm super happy with this setup. Have a listen to the PS2 startup sound recorded at 48 kHz and exported to FLAC.
My retro builds
