Reply 181 of 463, by red-ray
The latest CPUZ_x32 crashes, but CPUZ_95 runs and I suspect you may wish to use the C3-M logo
file.php?id=76000
Reply 182 of 463, by Slashzero
Sorry, my 30GB Maxtor drive I dug out of storage and was running Windows 98SE on died. I’ve swapped to a 60GB drive and am in the process of setting everything back up.
I will test this later.
Update: Man, I had to reinstall windows a few times. Installed drivers in the wrong order and WIndows 98SE went all sorts of wonky. Anyway, I'm back up and running now. I will download CPU-Z from the original post and try it out.
Update 2: So, I did try it out on my Windows 98 machine, and it detected everything perfectly. I am now working on my other desktop, which was running as an unstable Windows Vista machine. I just reformatted the drive, and am running XP Pro (and posting this from the XP machine). Once I get the video drivers, and sound card drivers installed, I will run CPU-Z on the Pentium D machine as well, for science.
Reply 183 of 463, by Slashzero
I’m trying to run the Win95 version, but it caused a BSOD when I ran it. Attaching image so you can see the error.
The attachment 01238D65-D8A5-4F2F-A20F-EC3A145CC738.jpeg is no longer available
I reset the laptop, and tried again. Made it to 22%, and the system froze.
Had do do a hard reset. Control-Alt-Delete did not work.
Tried a third time. It is consistently locking up my laptop at 22% (Monitoring).
The attachment 34F00CAD-29E2-4A80-BB33-4E6CC9F28CBE.jpeg is no longer available
Reply 184 of 463, by red-ray
Slashzero wrote on 2020-02-12, 03:03:
Try editing cpuz.ini and changing Sensor=1 to Sensor=0
Reply 185 of 463, by Slashzero
red-ray wrote on 2020-02-12, 08:45:
Thanks! I will try that tonight and report back.
Reply 186 of 463, by CoffeeOne
Last but not least, I am going to the cpu-z with the antique computer (Micronics ASIC EISA mainboard, 133MHz Kingston Turbo chip, 64MB 30 pin SIMM RAM, only EISA slots) as well.
On Windows 98 SE I have to use the Vintage edition 1.01.
So I started it and ***boom*** blue screen, but fortunately windows kept running, no reboot necessary.
But I very quickly found out, how I could run it:
I changed in the ini file "SPD" to 0 and it worked.
The cpu is detected well, the mainboard (and so the 256kB L2 cache) and the graphics card are not detected.
Reply 187 of 463, by Slashzero
So, the zip file didn’t have an ini file to start from. It just had the single exe. I suppose I could create an ini file and put the single setting in it, and hope it reads it.
Reply 188 of 463, by red-ray
Slashzero wrote on 2020-02-13, 05:00:
I would copy the cpuz.ini from a different system or you could paste as follows into one.
[CPU-Z]
VERSION=1.9.1.0
TextFontName=
TextFontSize=14
TextFontColor=000080
LabelFontName=
LabelFontSize=14
ACPI=1
PCI=1
MaxPCIBus=256
DMI=1
Sensor=1
SMBus=1
Display=1
UseDisplayAPI=1
BusClock=1
Chipset=1
SPD=1
XOC=0
Reply 189 of 463, by red-ray
The CPUZ Vintage Edition seems to have issues that CPUZ_x32 does not so I suspect some bugs crept in, further both the 32-bit builds report the incorrect number of cores even though CPUID 0000000B correctly reports 18 cores to 32-bit programs.
file.php?id=76852
Reply 190 of 463, by Slashzero
red-ray wrote on 2020-02-13, 09:42:
The CPUZ Vintage Edition seems to have issues that CPUZ_x32 does not so I suspect some bugs crept in, further both the 32-bit bu […]
file.php?id=76852
Locks up in the same spot. 😒
Reply 191 of 463, by red-ray
Slashzero wrote on 2020-02-14, 00:11:
Well try setting others to 0 rather than 1 'till the issues goes away!
Reply 192 of 463, by agent_x007
Any chance of making FSB visible together with RDRAM clock speed ?
The attachment S423 P4 1,5GHz CPU-z.PNG is no longer available
Reply 193 of 463, by Machine Monarch
Tried the beta version cpuz_w95.zip (cpuz_w9x.exe) on my Toshiba Satellite Pro 430CDT laptop. It loads until 22% and then it either freezes up the entire machine or screen goes black and nothing responds until I force restart it.
Processor is an Intel Pentium 120Mhz (2.9v/3.3v)
For what its worth here's some additional info about the processor;
External data bus width: 64 bit
External data/address bus speed: 66 MHz
Integrated Coprocessor: Yes
Processor Cache: 16KB: (8KB code; 8KB data)
Reply 194 of 463, by douglar
Is it possible to start the CPU benchmark without a mouse?
I didn't see a hot key and I could not figure out how tab through to the button.
Reply 195 of 463, by CuPid
agent_x007 wrote on 2020-02-23, 22:28:
yes, I check and let you know.
Machine Monarch wrote on 2020-02-25, 22:16:
Can you please edit cpuz.ini and set Chipset=0 ?
What is the last message displayed on the progress bar ? (processor, memory ...)
douglar wrote on 2020-03-02, 16:22:
Good point, I'll add a hotkey.
I need a vacation.
Reply 196 of 463, by appiah4
Do you need information on AMD K5 or Cyrix 6x86MX processors?
Reply 197 of 463, by CuPid
appiah4 wrote on 2020-03-04, 14:16:
in theory the K5 and the 6x86MX should be well supported, but if you have the opportunity to run a test and notice a problem, it is welcome.
I need a vacation.
Reply 198 of 463, by appiah4
CuPid wrote on 2020-03-04, 16:31:
I will check with both when I install Win95 tonight.
Reply 199 of 463, by lordmogul
Not really odd, rare or unusual hardware, but I will put it up anyway for completion sake.
hardware tested:
CPU: Pentium 3 933EB || overclocked to 1035 MHz (148x7.0)
Graphics: GeForce 3 Ti 200
Motherboard: Asus CUSL2-C (intel i915EP)
RAM: 256 MB PC133 SDRAM (Infineon) CL3-3-3-5-7 || overclocked to 148 MHz CL3-3-3-7-9)
Tested under Windows 98 SE with the 1.01.0 vintage edition and the old 1.78.1 version that does run on 9x, and both as well as the latest version under XP Pro SP3
benchmark
Benchmark does a little better under XP, but seems to be within margin of error (<2%), same as with FSB speed (<0.1% difference, but consistently the same values even after restarts)
(I can rerun them on default clocks again if you want)
pictures:
main screen under 98 SE
benchmark under 98 SE
about screen under 98 SE
main screen under XP
benchmark under XP
about screen under XP
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
