First post, by roll_over_dj
Here's my problem:
I have an LCD monitor first off.
When I run DOSbox, and I try to go into fullscreen(alt+enter), my screen goes into stripes of red, green, blue, and white; then the screen changes and I see a grey screen; then the screen changes again and goes go a blank white screen.
The 3 screens then loop over and over.
When I press ALT+ENTER again, it goes back to a normal window.
I should also note that I can hear the sounds of a game(if I start one).
Everything works perfect until I want to change the window into fullscreen.
I am pretty sure that it is something to do with my monitor, but I am unsure.
Any help with this issue is very much apprieciated.
Thanks in advance.
