Prince of Persia 3D on Windows 10
First post, by Presbytier
So I have my original CD's and I can install the game i can install the patch 1.01 and I even use the unprotected pop3d.exe, but nothing I do can get this game to run on Windows 10. What happens is the game loads to a black screen then drops back to the desktop. i honestly would love to play this again, so i was wondering if anyone here has had any luck getting it to run.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
Reply 2 of 61, by Presbytier
yeah I actually tried that and it did not work.
Reply 3 of 61, by bloodem
Here's a guide that I wrote for myself a few months ago.
TESTED & WORKING ON WINDOWS 10 64 BIT v1909 (GeForce RTX 2060 @ 2560x1440) with some issues, see below.
1. Install Prince of Persia 3D from CD1 2. Extract PoP3D_Unpacked_Patch_v1.01.rar to the installation folder, overwrite all file […]
2. Extract PoP3D_Unpacked_Patch_v1.01.rar to the installation folder, overwrite all files.
3. Extract the POP3D NOCD.rar patch in the installation dir, overwrite exe file.
4. Extract dgVoodoo to the installation dir and run dgVoodooCpl.exe. Go to the DirectX tab, set forced resolution, max VRAM to 128 MB (don't set it higher, seems to work better with max 128). Hit Apply & OK.
5. Install Riva Tuner. In the RivaTuner configuration, add the game exe and set a frame cap of 60 FPS.
6. Copy options.sav from the pop3d-resolutions.zip (the one from 1920 x 1080 should work fine for 2560 x 1440 too)
6. IMPORTANT: Even with the NO CD patch, CD2 must be inserted in order to play the game! So.... insert it now! 😀
7. Run the game (on the first try it might not work, until Windows 10 first applies the compatibility settings automatically).
8. After the game starts, sometimes the performance can be pretty bad (6 - 7 FPS) and CPU usage (as shown by MSI afterburner with RivaTuner) is very high on one core: 100%.
The workaround for this is to start the game, load the level (don't do this while in the menu) and then hit ALT - TAB.
This will minimize the game and after you maximize it again, CPU usage will have decreased to 30 - 40% and performance will be perfect. If the prince keeps jumping after you return to the game, hit the ALT key a few more times and he will stop 😀 FYI, this issue seems to go away after some time (maybe in some cases it won't even appear in the first place).
NOTE: If you want to see the intro movies, you must install "Quicktime alternative.rar" (located in the "OTHER TOOLS & PATCHES" folder)
SOLUTIONS FOR POTENTIAL ISSUES:
1. In case of problems during startup: first thing to try is disabling DPI scaling (Right click on desktop --> Display settings --> Change the size of text, apps and other items --> 100%. If this is higher than 100%, it can cause many issues with old games!
2. In the second level, when you enter the water there are some graphical issues with dgVoodoo (missing textures, basically you can't see anything while you are submerged in the pool).
The workaround is to use DDrawCompat v0.2.1.zip instead of dgvoodoo (just delete the dgvoodoo files and extract the ddraw.dll in the game dir).
Make sure to disable DPI scaling as specified above (or you can try the settings in DPI_compatibility_settings.jpg) and copy again the options.sav for 1920x1080
(the disadvantage is that the game will not be forced to run at 2560x1440, so with DDrawCompat v0.2.1 the game will run at maximum FullHD, but at least you can get passed the water swimming sequence).
3. If you have issues with missing textures use the Geometry patch.
- Delete the <game dir>/Geometry folder
- Extract the Geometry archive in the game dir.
For further problems, visit website: http://popuw.com/download3.html
I've uploaded all relevant files to my Google drive:
https://drive.google.com/open?id=15PJvGmtfs5w … GNJXjb72yIcXD8W
Let me know if it works for you. 😀
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 4 of 61, by Presbytier
I gave it a shot followed your directions to a T and it’s a no go. This seems to,mirror what I’m reading everywhere. Some people can get the game run others can’t. There seems to be no real pattern as to why either. Anyhow probably going to give up trying to run it on 10 for awhile.
Reply 5 of 61, by bloodem
Strange. Did you try to uninstall it first (and delete all remaining files)? Maybe your earlier tests have caused some other unforeseen issue...
I actually just tried my guide on a second PC with Windows 10, which is quite different from my main rig (fresh install with the latest updates + latest drivers + basic software like Google Chrome) and it works.
However, both PCs have nVidia cards (RTX 2060 on the first / GTX 1070 on the second). Maybe you are using an AMD video card (this might explain the behavior - there could be a dgVoodoo bug on AMD cards)?
Just as an FYI, my main PC:
CPU: AMD Ryzen 5 3600X
RAM: 32 GB
GPU: nVidia RTX 2060
Windows 10 Enterprise
Second PC:
CPU: Intel Core i5 7600K
RAM: 16 GB
GPU: nVidia GTX 1070
Reply 6 of 61, by Presbytier
I did a fresh instal. Honestly I’m pretty perplexed by the problem.
CPU: i7-8700k
RAM: 16gb
GPU: Nvida GTX 1080
Windows 10 Pro
Reply 7 of 61, by bloodem
Indeed, very strange. It should work without too many headaches, your configuration is very similar to mine.
And the behavior is the same, black screen then back to desktop? Is the game still started after that, do you still see it in the process list, is it minimized or simply crashes and exits?
Also, are you sure you've used the exact files/archives from my Google drive, no other changes?
Reply 8 of 61, by Presbytier
Yeah it launches to a black screen and crashes. This was the behavior before I did a clean windows installation as well. I used only your files nothing else.
Reply 9 of 61, by bloodem
This is a real mystery. I don't understand what the delta is... maybe the installation location. I installed it in D:\Games, maybe you installed it in the default location?
Did you try running the game as administrator?
Reply 10 of 61, by Presbytier
I have tried both the default and non default and have tried admin mode too. It’s a pretty perplexing mystery to me. I honestly wished I had another pic just to see if it’ll run.
Reply 11 of 61, by bloodem
Too bad. 🙁 The only thing left is some other device / driver that is probably misbehaving. For example, in my case, I'm using the onboard sound card (Realtek High definition Audio on both systems).
Another thing worth investigating is the logs inside the POP3D directory. Maybe one of them will provide more information about what the exact error is.
Reply 12 of 61, by BEEN_Nath_58
Presbytier wrote on 2020-04-10, 05:15:
What I did is, install the game, update to the latest version using the unpacked update(the setup update doesn't work, it installs update in WINDOWS folder) and use a no-cd file. Then drop dgVoodoo 3Dfx .dll files and configure the software to use 3Dfx Voodoo2 and it ran.
SINCE YOU GOT A BLACK SCREEN, It might have had happened because you didn't use dgVoodoo or nglide. They will most probably fix the black screen issue.
Can you submit me that .exe file, I kinda lost the one I used?
Reply 13 of 61, by Presbytier
Discrete_BOB_058 wrote on 2020-04-20, 19:59:
What I did is, install the game, update to the latest version using the unpacked update(the setup update doesn't work, it instal […]
SO I reinstalled drop the patch then dropped nglide into the folder. I can get to the main menu of the game but it crashes after the video plays on new game. I do not see a way to configure the game to use nglide??? Is there an option in an ini?
PS Which file do you want? The Cracked EXE?
Reply 14 of 61, by BEEN_Nath_58
Presbytier wrote on 2020-05-02, 04:03:
I need the cracked exe.
Don't drop nglide into the folder.Either drop the glide,glide2x files of nglide from the Windows directory to the game or just install the nglide and configure it as you want.If it still crashes,try dgVoodoo.
Reply 15 of 61, by Presbytier
Yeah nothing seems to work to get it to run and it just crashes with dgvoodoo. To be honest I don’t even think it is usesimg nGlide either as even if I just leave all 3 glide.dll in the folder I never get the splash screen which I turn on for testing. I got the crack from here https://popuw.com/download3.html
Reply 16 of 61, by BEEN_Nath_58
Presbytier wrote on 2020-05-02, 13:11:
The mistake was, POP3D doesnt use Glide. It uses DirectX as the game has worked fine on extracting the files from MS/x86 folder of dgVoodoo.
Reply 17 of 61, by synrgy87
Can't even get the installer to run on Windows 10(64bit) When i tried. So you're doing well 😁
Reply 18 of 61, by BEEN_Nath_58
synrgy87 wrote on 2020-05-03, 13:01:
How you couldn't get it to. Run. Did you use any disk mounting softwares? The setup is 32 bit so there shouldnt be any problem.
Btw which build you used. I used 1909 64 bit pro
Reply 19 of 61, by synrgy87
Discrete_BOB_058 wrote on 2020-05-03, 15:11:
Same 1909 Pro 64bit, using retail CDs, installer / setup just doesn't start, will look into it more after work, not trying to hijack thread.
