HWiNFO for DOS resurrected !
Reply 360 of 907, by feipoa
Ran v6.1.0 on an SXL2-50 system with ALi M1429 chipset.
1) HWiNFO hangs after leaving the ISA/VLB "other devices" section. The Info menu is displayed with Mainboard info highlighted during the hang.
2)The Cirrus Logic CL-GD5428 doesn't show up in the ISA/VLB section but shows up under video information.
3) IRQ assignment correctly shows the AHA-1522B installed, but under SCSI Host Adapter Information, it is listed as the AHA-1520. This system is using the 1522B.
4) Math Co-Pro speed is listed correctly, but the speed is shown as 27.5 MHz. Should be 25 MHz.
Reply 361 of 907, by Mumak
feipoa wrote on 2020-04-29, 08:01:
Ran v6.1.0 on an SXL2-50 system with ALi M1429 chipset. […]
Thanks!
1) Please try to disable "Check 3Com EtherLink III Adapter" option if that will solve the hang. If not, can you please take a screenshot of the hang?
2) ISA graphics cards are currently no mirrored in this section.
3) SCSI Host Adapter Information comes from the ASPI driver, so that one is responsible for providing a correct name.
Reply 362 of 907, by feipoa
Screenshot of the hang.
Reply 363 of 907, by feipoa
I think the hang is caused by pressing the ESC key after viewing ISA/VLB. When I press the left arrow to exit the submenu, the hang does not occur.
EDIT: Nevermind, I cannot reproduce the hang everytime. But sometimes ISA/VLB shows "no devices", but if I run it again, it finds the 3Com etherlink III. Every other time, it doesn't find it, then it finds it.
Reply 364 of 907, by Mumak
So it does hang also when the 3Com scan is disabled?
Reply 365 of 907, by Mumak
Try this version if you can reproduce the hang here. It should also update the FPU clock:
[build pulled]
Reply 366 of 907, by feipoa
Yes, happened with the 3com scan disabled as well. I'll have to check that tomorrow.
Reply 367 of 907, by hasat
Here is report from my HP Vectra N2 4/50.
Specs:
Intel 80486 DX2/50
32 MB RAM
Cirrus Logic CL-GD5434 with 1 MB RAM
10Mb LAN card based on AMD AM79C960KC chip
270 MB Quantum Maverick HDD
Crystal CS4235-JQ sound card.
Major problem found:
HWINFO hard freeze in peripherals screen with Super I/O and keyboard controller detection enabled. With EMM386 loaded "Fatal error, cannot continue" message apears with nothing in bottom right corner. Without EMM386 loaded, no error message, but still computer freeze on this screen and in bottom right corner is written t4558]
Minor problems:
Motherboard chipset is VLSI VL82C483FC3 (HWINFO detected VLSI VL82C330, Rev 0)
Sound card is Crystal CS4235-JQ (HWINFO detected Crystal CS4236)
Super I/O chip is SMC FDC37C663QF.
Keyboard controller is Intel N8042AH.
OS is MS-DOS 6.22 with Windows 3.11. Tested in DOS.
Reply 368 of 907, by Mumak
hasat wrote on 2020-04-29, 13:32:
Here is report from my HP Vectra N2 4/50. Specs: Intel 80486 DX2/50 32 MB RAM Cirrus Logic CL-GD5434 with 1 MB RAM 10Mb LAN ca […]
Specs:
Intel 80486 DX2/50
32 MB RAM
Minor problems:
Thanks! Please try this build if it still freezes at Super I/O check, I expect it to report the FDC37C663QF instead of freezing:
[build pulled, newer available]
Reply 369 of 907, by hasat
Still freezing, attached picture is without EMM386.
With EMM386 is same plus message "Fatal error, cannot continue".
Reply 370 of 907, by Mumak
That looks more like the KBC check is the problem here. But also wondering why the FDC37C663 wasn't detected, in the build above I added detection per its datasheet.
Reply 371 of 907, by feipoa
Mumak wrote on 2020-04-29, 09:28:
HWINF610.ZIP
Hung before seeing the welcome screen with this new fix.
Reply 372 of 907, by Mumak
feipoa wrote on 2020-04-30, 07:46:
HWINF610.ZIP
How come, there were no changes that could cause such issue. Is that hanging always, is at least the background displayed?
Reply 373 of 907, by feipoa
Background displayed, but hangs before welcome screen. I'm in the process if putting the previous version back on to ensure that the welcome screen is displayed.
Reply 374 of 907, by Mumak
HIMEM and/or EMM loaded? Did it at least display "Reading Data ..." and the title "HWiNFO v..." on top of screen ?
Reply 375 of 907, by feipoa
Yes.
Reply 376 of 907, by Mumak
In case you have HWINFO.INI file there, can you try to delete it?
Reply 377 of 907, by feipoa
Previous version works. As before, sometimes it shows the 3Com under ISA/VLB, sometimes it does not. At times where it says "No Devices found", if I press ESC, ESC, ESC to get back to the home screen, the system will hang.
Reply 378 of 907, by feipoa
I leave hwinfo.ini in there so that CPU methods 1 and 3 are disabled, otherwise the CPU gets reset to 1x mode. You should be able to detect the CPU in 2x mode, do the CPU reset, then write 2x mode back to the CPU register.
Reply 379 of 907, by Mumak
feipoa wrote on 2020-04-30, 08:23:
OK, here another build to test:
