First post, by lmttn
lmttn
Offline
Many DOS games change resolutions when the need arises: for example, an FMV might run at a different resolution as the actual game, whose resolution may differ from the game's menu screens. In windowed mode, changes in resolution also resize the window. Is there a way to make DOSBox run in a window that is of a fixed size?
