First post, by lmttn
Many DOS games change resolutions when the need arises: for example, an FMV might run at a different resolution as the actual game, whose resolution may differ from the game's menu screens. In windowed mode, changes in resolution also resize the window. Is there a way to make DOSBox run in a window that is of a fixed size?
Reply 1 of 2, by jmarsh
Set output to opengl (or any other option that supports scaling).
Reply 2 of 2, by lmttn
That fixed it, thanks!
